3rd function not working
FarmtoLake
Kubota LX2610
Jan 13, 2022
Ontario, Canada
I recently upgraded my tractor and now have a MX5400. I added the 3rd function at the dealer. The tractor works great so far. Today, I connected my HLA grapple that I haven't used for about 2 years (stored outside) and the grapple won't open. I double and tripled checked the hydraulic connections. Has anyone had issues with the grapple hydraulic cylinder after siting a while? I am getting no movement what so ever from the hydraulic, however, can manually move the grapple top claw an inch or so by lifting it. Any suggested next steps to diagnose?
Caden
1979 B7100
Apr 16, 2026
231
111
Is the 3rd function controlled by a electric switch in the loader controls?
If so I would look at that angle rather than at the grapple its self.
The grapple we have at work can be moved an inch of two by hand when unhooked so I assume that is "normal".
Trustable
l2501HST
Jul 5, 2022
397
411
I can’t remember his name, but someone on here had an issue with his lift cylinder on his PTO from being stored in the up position. Maybe something similar happened here hopefully he sees and can chime in.
6,488
I second the recommendation to check the electrical part of the third function assuming it’s an electrically controlled diverter rather than a fully mechanical valve.
I have a dealer installed WR Long diverter type third function to run my grapple. Just today, while doing storm cleanup, it refused to open while I was trying to dump a load of brush. There are two little wires that go from the loader control grip where the switch for the third function is housed to the relay for the diverter. There’s a little plug in the side of the control grip for those wires. It looks like it would be more at home inside a computer case than on the outside of a tractor. I unplugged it. Plugged it back in. Worked another 4 hours without further problems. Second time I’ve had to do that in 650 hours. First time was at about 300 hours.
Every time I’ve had issues with the grapple lid hydraulics, it’s either been electrical (in my case, that little plug), or a quick connect that wasn’t seated (even if it looked like it was).
Chances it’s getting pressure and flow but the cylinder is the problem are pretty small. If that’s the case, you should see the hoses flex/pop a little when you actuate the third function. If you have hoses on the tractor side of the quick connect and have a problem with the quick connect, you should see that little bit of movement on the loader valve to front quick connect hose, but not on the quick connect to grapple lid cylinder hose.
You say you’re getting nothing at all, so I’m betting on an electrical issue. Quite likely a corroded or loose connection somewhere.
#40Fan
576
412
Is it a true 3rd function or a diverter?
One button or two on the joystick control?
FarmtoLake
Kubota LX2610
Jan 13, 2022
Ontario, Canada
Thank you all for your replies. Problem solved. It was electrical. My old LX2610 had two red buttons on the joy stick to operate the grapple. I used the same dealer when I bought my MX5400 and they installed what looked like the same 3rd function device. As it turns out there was an additional switch on the right side of the of the 3rd function buttons to activate the 3rd function. Once activated, the 3rd function works great. No issues with the hydraulics even though they sat outside for 2 years. The buttons are reverse to my preference (top is close and bottom is open), however, I will just switch the hydraulic connectors on the grapple to solve this last issue. Thanks again!
FarmtoLake
Kubota LX2610
Jan 13, 2022
Ontario, Canada
thank you, problem solved. It was electrical.
FarmtoLake
Kubota LX2610
Jan 13, 2022
Ontario, Canada
