One of the main issues with 3pt log splitters is slow cycle times. It takes a pretty hefty flow rate to get reasonable speed and most small utility tractors don't have the output needed. My newly acquired L3901 @ 6+ GPM was a big improvement over the old B7200 @ a scant 4 GPM but still pretty slow. It turns out the valve on the splitter had developed a bad leak so when I went to replace it I decided to try one of the "high speed" valves.
They have a regen circuit on the extend port and a 4 position spool. The 4th position actuates the regen for rapid extension and when the wedge hits the log and stalls you drop back to the third position for full splitting pressure. Same basic idea as a two stage pump but it only works one direction. I had my doubts but they are not expensive and I needed a new valve anyway so I figured why not. Much to my surprise the increase in speed is substantial. Here is a short video clip showing the relative speeds of extension vs retraction. I have only split a few rounds as a test but right now it looks like a big winner.
Hydraulic Log Splitter Control Valve w/ Return Stroke Detent, 21 GPM
FREE SHIPPING Hydraulic Log Splitter Control Valve w/ Return Stroke Detent, 21 GPM
summit-hydraulics.com
