3pt Log Splitter
Frank minarchi
B3200 loader,mower
Sep 24, 2012
41
Edmonton ab Canada
Thinking of hooking up a 3pt log splitter to my B3200 and was wondering can I hook the hydraulic lines for the log splitter valve up to my backhoe lines in the back? Or we're would I pick up a 3rd fiction on that tractor since those lines are used up for the backhoe when attached . Thanks
barncat
L3200HST4X4,66"detach FEL,60"BB,SplitFire30"3pt,KKII,48"Forks
Oct 23, 2012
41
Indian Springs, AL
I had the same question last year and discovered set up questions I could not find the answer to with the valving on the splitter, recycling the oil or potential blinding the recycle flow when hooked up to the implement. There was also the $700 plus fee the local Kubota tractor dealer wanted for the installation (if I could tell them how I needed it hooked up). I solved all this by using a PTO driven self contained hydraulic log splitter set up. This was cheaper but it does not allow for future implements.
Which 3pt splitter are you considering…I found the Canadian built SplitFire to be the most incredible machine…very happy with it.
8,846
It's not advised to hook up to the tractors hydraulics to run a log splitter as it will be extremely slow.
If you do go ahead and do it you need a ported non-valve controlled outlet to run it, as the valve on the splitter will do the work.
Frank minarchi
B3200 loader,mower
Sep 24, 2012
41
Edmonton ab Canada
I was thinking the Speeco splitter but maybe i should just go with the self contained one with its own motor. But does that mean with my power beyond line tied up for my backhoe connection that i cant even put a 3rd function on my loader like for a grapple or something?
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Implements are priced according to the volume of sales. Since "they" sell a jillion self-powered log splitters for every 1 3PH hitch model, you can probably get better for less going the self powered route.
Wolfman's comment on the speed is very true - think SLOW with the tractor hydraulics.
You can still put a grapple or other implement on the tractor by plumbing it in series with the loader valve. That is what my dealer did when he gave me remote hydraulics lines for my L3200.
olthumpa
L275
May 25, 2011
1,501
Maine
I prefer a separate splitter to one attached to the tractor. This leaves the tractor free to do other things such as move split piled away from the splitter and move un-split wood closer , or any other tasks.;) Also saves hours on the tractor.
Just a thought.
Dwilson
b3200
Nov 25, 2014
Indiana pa 15701
I have a B3200 and have a question, I do not have a front loader on my tractor but wanted to try and hook up a log splitter, it seems like there is no presure in the hydraulic lines, is there a way to turn this on, I don't have a manual and found nothing on line to help me.
