The 3pt hitch control lever on my L3301 seems harder to move than it needs to be. When you're trying to raise or lower a box blade I inevitably overshoot and have to try and nudge it into the position I wanted.
Looking from the back of the tractor, the lever runs down to a shaft running right to left (from the lever through the transmission and out the other side.
I searched the manuals (unsuccessfully) looking for any sort of lubrication or adjustment of the preload on the lever and didn't find it.
The 3pt hitch raises and lowers fine and holds position properly, so I'm fairly sure it's just a linkage issue - either lubrication or adjustment of preload, but maybe both.
Can anyone help?
Thanks in advance.
Can anyone help?
Thanks in advance.
