3PT hitch doesn't stop going up
Bill K
2000 L35, BT900 BH, Woodmax chipper, Titan forks, Kubota grapple
Oct 16, 2021
Foster, RI
Hi All, new here and new to Kubota. Just purchased a L35 and when I have the 3PT all the way up it appears to be still pumping fluid to the arms unless I open the "lock out" valve ( one between my knees). Then it appears to bypass the fluid to the arms. Is this normal? Thanks
Bill
2,596
There is a feedback rod involved that limits how far up the arms go.
Yours may need adjustment?
What you described sounds abnormal to me.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Russel King sounds right. I recently had to adjust mine to get the draft control to work properly. I went too far and it wouldn’t stop up pumping and caused the relief valve to to activate.
Bill K
Oct 16, 2021
Foster, RI
Thank you....I know where the feedback rod is (with the two nuts) . I just removed the backhoe to install a logging winch and haven't found a good way to adjust rod. Are there any links to procedure? I have tried search to no avail.
9,976
I'll send you the info.
Look at your PM's, envelope top right.
