3pt arms not lowering under their own weight
dje
BX23S
May 30, 2023
11
Vancouver Island, Canada
I tried to lower the mower arms on my bx23s, but found I had to manually push down both the 3pt hitch as well as the mower arms (with a bit of manual downward pressure).
Should I expect both to lower under their own weight, or is this normal?
6+ year old tractor and I'm guessing neither have ever been used, so it's not surprising that they're stiff. I sprayed many of the joints liberally with wd40.
Also, is there a general spray lubricant people would recommend to get these parts cleaned out and lubricated? (Other than wd40)
Thanks.
#40Fan
381
260
Check the adjustable valve under and in front of the seat.
3,631
hodge
Nov 19, 2010
2,950
514
Love, VA
This- the first thing to check. It controls the drop rate.
5,175
Thanks.
WD-40 is a satisfactory wristwatch lubricant, but not good for much of anything else.
Brakleen, then.....
Boshield , LPS-3, Fluid film, etc.
