3830 GST Bucking
RoofDoctor
Florence
i have a 06 3830 GST 4x4 that has developed a slight buck when going from N to F or R. It does it 3-5 times then stops till you have to change drives again. i did find i was a little low on hydraulic fluid even though i can not locate a single drip. i did not have anymore fluid to fill back to up, but i know someone's went through this and may shed some light in case that does not clear it up. Possible pressure sensor or anything. There is no sounds and the weekend before ran like new. i did change the filter about 2 months ago and replaced the fluid i lost then, but no issues till now.
9,139
Low fluid could very well be your issue.
Did you use a Kubota filter and Kubota UDT or SUDT on the change add?
You may well be over due for a full fluid and new filter again too.
RoofDoctor
Florence
so... i got it back within fluid range and the bucking seemed to be a lot better. after about 2 hours it started bucking again mostly when going from N into Reverse. i parked it and adjusted the clutch pedal because it was out of range. that didn't help the issue. it does seem to whine louder now when i have my disc picked all the way up. if i lower in 1/2" on the selector it stops. I'm going to do a complete new kubota filter and UDT fluid change and hope it solves the issue. where do i go from there if it doesn't work?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Your three point hitch may be adjusted so it is going to high. that is not good as it causes the relief valve open which is likely the whine you are hearing.
9,139
Yes like eserv said, you need to adjust the three point feed back linkage to keep the three point from going into relief. ;)
