T tractorproJohn New member Equipment L2850 with a BF500 Loader Jul 28, 2019 7 0 1 River Oaks, TX Jul 28, 2019 #1 I have a L2850 with a BF500 front end loader and my 3 point will not work unless I curl the bucket on the loader. Does anyone know what this could be and what I need to do to fix the problem. Thank you in advance. John
Dave_eng Well-known member Lifetime Member Equipment M7040, Nuffield 465 Oct 6, 2012 5,128 933 113 Williamstown Ontario Canada Jul 28, 2019 #2 More history would help. Is this a recent problem? Did you remove, replace any hoses on the loader? I do not have a manual for your tractor but most feed the rear of the tractor through a power beyond port on the loader valve. I suspect you have a hose in the wrong place. Dave
Kennyd4110 Well-known member Vendor Member Sep 7, 2013 1,171 336 83 Westminster, MD www.boltonhooks.com Jul 28, 2019 #3 Have you added a new valve? If not, or nothing that Dave suggested than you need to do a pressure check next.
B bxray Member Equipment Bx25d Dec 1, 2014 712 2 18 Cleveland, ohio Jul 28, 2019 #4 Sounds like a problem in the fel control. Is it sloppy? Can you wiggle it and make the 3pt work? It is blocking the flow somehow. Ray
Pau7220 Well-known member Equipment L3650 GST, Landpride TL250 FEL w/ Piranha, 6' King Kutter, GM1084R Finish Aug 1, 2017 785 276 63 Scranton, PA Jul 28, 2019 #5 Try disconnecting and reconnecting the quick couplers. I had a similar situation when a stick hit one and partially disconnected it. Last edited: Jul 28, 2019
rbargeron Well-known member Lifetime Member Equipment L5450, L48, L3250, L345 never enough attachments Jul 6, 2015 1,150 220 63 western ma Jul 29, 2019 #6 Check that hoses are located correctly at the hydraulic block - and control slot points to C Attachment shows hydraulic block 7 and valve 10 - OUT on block goes to P on valve (pressure) - T (tank) on valve goes to T on front of block - PB on valve (pwr-beyond) goes to IN on block - control slot on block points to C (loader bypass) Hope this helps, Dick B Attachments L2850 WSM page F.M-4.pdf 226.4 KB Views: 160
