3 point sprayer. Can my tractor handle it?
igizzzmo1
47
Elmira, Or
Can a B2650 kubota with loaded rears handle the weight of 40gallon sprayer on the back?
2,897
O hell yeah! :)
you are only looking at 400 pounds total!
Spray everything you got!:D:)
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
That will not be a problem. I use a cheap 25g tank / pump that sits in the loader bucket with a homemade 6' boom. For weed control, spraying is MUCH cheaper than any type of spreading / broadcasting product. Enjoy.
SLIMSHADIE
Kubota BX25D
Apr 10, 2013
445
Eureka,IL
I would think you would be fine, I use a similar 25 gallon setup on my Bx25. Most of the time Im only making multiple 20 gallon batches and even 10 gallons, easier to calculate but have filled it to the top and have had no problems. Worst case scenerio is not to totally fill it.
Oct 8, 2014
616
oregon
I run 25 gallons on the back of my ATV. Fill it half full of water and spray down a road to check the pattern. Adjust the booms up or down as needed.
