3 point quick change?
Pipewelder
B7100 with 425 original hours
Sep 28, 2014
27
Kenmore, NY
Question for everyone out there. Looking at a quick change set up for the 3 point. Looked at the Pat's system, as well as the standard 1 piece plate. Any advice? Pros and cons? Thx and God Bless
coachgeo
Nov 16, 2012
2,460
32
Southern OH
That's sweet the PAT's method. Been brainstorming on this too but my idea required modifications to the implement too. This is way better. Each Pat works sorta works like a Ringfeder type hitch.
I was thinking of forks that attach to the lower tractor bar that slide into slots on the implement with an auto latch of some sort that flips into pin holes or over a post. Only then have to attach the top link. But...... if you have to get off the tractor to attach top link.... you might as well attach the bottom links too.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Pipewelder,
We got the Pat's quick hitch and the longer top link from them. Pat's will extend your bottom links about 4 inches. It is a great system. If you combine Pat's with Hodges stabilizers you won't go wrong.
Pat's quick hitch makes it easy enough that my wife can hook up the 3 point implements by herself now.
We also considered the HF and other similar hitches and found them inexpensive and OK. We finally settled on Pat's. Even though they cost more, they are worth it.
Incorrect use of the HF types can cause fender damage. Dropping an anvil on your foot can also cause damage.
Burt
Pipewelder
Sep 28, 2014
27
Kenmore, NY
Haha, that's priceless!! Yeah Wiley Coyote hates those anvils as well. Pats looks like a good fit. How do you hold the arms steady as you're backing into them though? With the plate setup it seems as though it would remain stationary enough to hook. Then just lean back and trip the levers and you're off to the races. I don't have but a few implements but I need to make sure the dimensions will work. Thx and God Bless.
Tooljunkie
May 13, 2014
4,150
27
I bought a pair of quick connects. Upon moving things back, a couple shafts end up too short. My three point wont carry as much. My solution- make new lift arms and weld connects on the outer ends.
So far its working out good for my needs.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
So you shortened your fabbed lift arms the length of the Pat's like connects keeping the over all length the same?
Wbk
307
St Adolphe Manitoba Canada
Hi Pipewelder we have 3 Bx's with quick hitches, the one thing that you have to do is make all your implements adaptable which is usually adjusting the top link bracket. Once you've done that it only takes a minute to switch implements and with some (without PTO shafts) you don't even have to get off the tractor. They will also move your implement 4" back so before you buy make sure your drive shafts are long enough. Now that I've used them I wouldn't be without one.
SLIMSHADIE
Kubota BX25D
Apr 10, 2013
445
Eureka,IL
I went with pats because the few implents i do have, they are different widths. Yes i have to get off the tractor to hook up, but its better than stock. I made dollies for all my implements so i just roll them up and hook up. With Hodges stabilizers they are a perfect pair. They stick out a little farther as mentioned but i havent had any problems with my stock top link.
Pipewelder
Sep 28, 2014
27
Kenmore, NY
Thx everyone. I'm going to get on the horn later and see if I can't get some coming soon. Once everything is finished I'll be sure to post pics, Thx again and God Bless all and have a safe day.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Pipewelder,
Your arms will stay steady with Hodge's stabilizers. The distance between the various 3 points implements is easily handled. There is a very expensive tool...I use a 1/4" dowel. I mark the distance between the "flanges" of an implement I'm going to hook up, mark each with a different color marking pen AND name. That way, I can set the stabilizers exactly where I need to be when backing up. Most of our implements are within an inch of each other anyway.
Just back up slowly and square to your 3 point like Pat's QH videos show, lift, hop off, adjust your top link and get to work! Just watch out for that anvil!
Burt
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
If you purchase your attachments and select a common pin distances, you can avoid some of the changes noted earlier here to accommodate those different widths. Then you can live nicely and easier with the fixed systems.
HighSierra79
B7100d, M6800 w/FEL, 7' mower, 7' box blade, 42" LP tiller, 5' rake
Sep 1, 2013
74
MO
On the fast attach systems, we solved implement width by the purchase of 6ft Steel tubing, cut and slid those over the existing pins, then ran bolts thru original pin holes to secure. No more worry about narrow or wide. Run a HF QH on b7100. QH works on tiller, rake, two cultivators, 50 gal sprayer, 2row planter, etc. Oh, QH costs $103.84 to my door.
