3-point lever won’t stay up
Fastball
L2900, rear blade, finish mower, 200l sprayer, landscape rake
Feb 9, 2017
86
29
North Okanagan, British Columbia
Hi, all….I inherited my dad’s L2900. Runs great, does everything I want pretty much. One thing though - the three point lever by my right hip seems to vibrate down after a minute or two. i want it at setting 4, for example, to keep my implement at a certain height..but invariably, it sinks down to zero in short order. There is a nut kinda thing that you can tighten down in front of the lever, but I’d like to put the lever at 4 and it STAY there. is there something underneath that needs to be tightened somehow to stiffen up the 3-point lever mechanism? Or is that just the way it is? I have the 3-point lowering wheel between my legs turned so it sinks slowly.
Thanks in advance…
MOOTS
MX6000
Jun 27, 2019
2,144
2,637
Canton, Georgia
Follow the lever down to the transmission. Should be a nut with some washers, tighten the nut a bit.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
545
309
Mandeville Louisiana
My MX5100 has double nuts loosen the lock nut and adjust to the smoothness and holding ability you desire.
