3 point hydrolic problem
Logan Robertson
B7100
Feb 4, 2014
Collinsville OK
We have never repaired our used B7100 since we got it 10 years ago. The hydraulics are not leaking but when any thing is attached to the 3 point hitch and raised to the max, the 3 point hitch slowly goes down and the implement never stays in one spot. What is the problem???
9,412
The problem is a leaking valve or rings/seals on the lift cylinder.
But Reading your other thread I would do a complete drain and filter change before you do anything else, old hydraulic fluid can do a lot of strange things.
If it's an HST (pedal drive) use UDT fluid when you change it, not normal over the counter hydraulic fluid.
If it's a DT (gear shift) then to you can get away with any compatible hydraulic fluid.
