24” auger on a l3901
Rtckubota
Boones mill,va
Hey everybody
First time poster here. I’m in the process of building a pole barn and will need to auger around 35 2’x4’ deep holes. I have priced out renting a skid steer with an auger for a weekend and it’s aeound 600$. I have a friend that has a large pto auger capable of running a 24” bit.
Is that too much for my tractor and I should just pony up the money. Or can I take my time this will do fine? I understand I’ll probanly have to go down 12-18 inches, come up, go down again. But just don’t want to over stress anything.
Thanks!
3,956
Can you do it,, probably... If you friend has a larger tractor wit the 24 inch bit ask him to bring the whole rig over and pay him. While I understand about trying to save a buck where ya can, this might be one of those time spending a bit could save you more in the long run.. just MHO you understand
6,476
If you're going 4' deep and 2' diameter thirty five times, I'd go rent a machine and get it over with...unless you have a friend who is capable with the bigger equipment.
Sounds like you're building a hanger for your airplane!:D
prof.fate
75 L175, 14 toro timesaver, Landpride boxblade, countyline auger
Nov 9, 2017
155
Beaver, PA
39hp..should be good..depending on soil conditions.
As for rental costs...i'm looking at putting in about a mile high-tensile fence come spring...the fastest / easiest way is to hole/plant the corner posts and drive in the line fences.
Post drivers are pricey, and my neighbor has one..on a 70hp tractor, says my L175 won't run it. Drats. So either I talk him into letting me borrow or rent his tractor or I'll have to rent a driver.
Or spend a LOT of time digging holes...
SO..if you have a deadline, you spend the money and get it done. If it takes you 2 days longer to drill but 4 days to earn the $600..it pays to spend the time.
Another thing is your available time...I should have a couple of weeks off next june to do this work. So I could spend 12 hours a day pounding in posts and keep the rental cost to one day, maybe 2. Long tiring days...but the alternative would be drilling 200 ish holes and tamping in the dirt..that's a lot of long tiring days too!
