2021 SLV75
FG Ray
SLV75
Nov 20, 2024
Upstate NY
Starts and runs but stalls like it is'nt getting fuel, then cranks a while before starting
Changed fuel filter, drained water separator
8,671
Does it stall without any movement or control interaction?
Do you have the WSM (aka service manual)?
It would walk you through all the fuel system testing.
whitetiger
Nov 20, 2011
3,161
1,582
Kansas City, KS
Remove the hose from the rear-facing nipple in the fuel filter head and turn your key switch to the run position. Do not crank the engine.
See how much fuel flows from the hose. It should have a full pulsing flow. If it is just a trickle, remove the water separator from the machine and unscrew the bowl, removing it.
Remove the plastic screen from the separator, using a blow gun with compressed air, and blow air through the hole in the underside of the head that lines up below the shut-off valve. You will probably blow debris out of the inlet elbow. When it is clear, reassemble the separator and reinstall it.
Turn the key switch back to run and recheck the fuel flow.
RLBranham
SVL 75-2
Nov 24, 2024
Thank you. I had the same problem with my tractor. I followed your instructions and the problem is solved. I have been going through the fuel system, drained tank, changed pumps, but I had not disassembled the water separator. Thanks, again.
