Guys I just removed and cleaned fuel tank. replaced rusted sending unit, installed new filter and blew out all lines.
Tractor is running perfect untill i get up in the higher rpms. then it seems to be down on power. in neutral i can run it up to 2500 rpms and its sounds smooth. if i get in to say 2nd gear high and get on up in the rpm range or get it under load at that rpm range it runs rough. as long as i stay around 1500 or less its perfect. Im really leaning on bad injector(s) Thinking about purchasing set. do i need a special tool to remove them or will a 22m or 21mm which ever deep socket work?
Any thoughts on how to test before i remove or with this info yall think im on the right track?
