2013 Kubota M108S tractor won't start
Vanharlin Farms
Jun 8, 2025
Inola, Ok.
Tractor running fine one day, won't start next day. No power to fuel pump or suction control valve. All fuses okay. Jumped fuel pump and SCV. Fuel to injectors but still won't start. Shot it with short blast of ether and it started but died immediately.
5,646
this.... Shot it with short blast of ether
means.... probably time to buy a new engine
NOT having power to fuel pump and SCV might indicate several other 'things' do NOT have power and cause the 'no start' situation. A look at the wiring diagram will show that PDQ.
sad you used ETHER.. as it usually will destroy any Kubota diesel FAST
Vanharlin Farms
Jun 8, 2025
Inola, Ok.
I've used ether on many different diesel engines including many Kubota engines and haven't trashed one yet. Maybe its all in how you use it. I believe its the ECU but don't know how to confirm that. It has fuel to the injectors and I believe the ECU is not allowing them to operate correctly.
8,699
You need a dealer with a computer to read it.
