2002 BX1800 60" MMM Hyd. lift arms
The Toolman
BX1800 C-101 Wheel Horse
Mar 21, 2012
32
Lake of The Ozarks, Mo.
The right starts going up a 1/2 a second or so before the left one does. Are they on a single shaft an one is slipping or out of time with the other, or are they seperate cylinders/hyd pistons to pull then up?
Whats the cure, or is it something that just happens on this model machine?
Thanx.
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
On my bx2230, there are levers that come from the rear 3ph that lift the mmm. One side has an adjustment on it. The rear 3 point hitch is actually what lifts the mmm.
The Toolman
Mar 21, 2012
32
Thanx, ;) I found that rod an will try to adjust it one way or the other until they both move at the same time.
Ron
