1984 kubota b7100 hst
Pierrecnwl
Kubota b7001
May 26, 2023
Quebec
Hi
I purchased this morning. Battery pole was on the wrong side( reverse polarity). the engine wasn't turning the wrong way, i was under the impression dc motor when reverse polarity, they turn the opposite side, 1984 b7100 hst is that posituve ground on negative polarity?
5,179
Hi
purchase this morning. Battery was inverted guess what motor was turning opposite side.Didn’t know it coulb be possible but yes it was. Seller complains transmission problems. It is working ok on low idle bit high hidle it doesn’t go anywhere. Notice lots of foam and bubble in oil. I suspect it doesn’t have the righ oil and might have hose strainer clog. I know you guy’s are very knowledgeable
Thanks for your help
"battery was inverted"???
Translation issue?
Perhaps ....battery connections were reversed?
9,335
Even with the battery reversed the motor can not be started and run in the reverse rotation, it's impossible.
1: The Bendix will not engage on the starter
2: The firing pattern of the engine would have it injecting fuel at the wrong direction of the stroke.
As far as all the other issues go, there could be mutiple reasons for those issues.
