14 SVL90-2 has an E9200 code
Seedub930
2014 Kubota svl90-2
Mar 19, 2023
Missouri
Have a 2014 svl90-2 showing a E9200 code. Service manual says it is an issue with the mass air flow sensor. Both the inner and outer air filters were replaced 10 hours ago. I also removed the sensor and cleaned it. A new air flow sensor is $400. Hoping to find an easy fix before spending the money for a service call and new sensor. Anyone have this error code before and able to fix it themselves?
Seedub930
2014 Kubota svl90-2
Mar 19, 2023
Missouri
The manual says to use “diagmaster” to determine the cause of error. I am trying to avoid calling my local Kubota dealer to fix it. They are an hour away.
9,605
Then that's what you'll have to do, if there was a manual test they would tell you.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
I agree with NIW, but, how did you clean the mass air flow sensor? Does it have power and ground at the wires(I am assuming this is a three wire sensor)? I have had some luck using a MAF cleaner(CRC).
