10 hour break in service...
Zaicran
B2650, 72" MMM, LA534+QA, RCR1260
Oct 8, 2019
72
Morganza, MD
So, my B2650 is at 7.5 hours...it will be easy to hit 10 hours in the next few weeks.
Is the 10 hour service something I can do at home myself if I had good instructions or do you recommend I let my local dealer take care of it/it is supposed to be done by dealer?
If the dealer does it...do I need to haul it to them? Because I still haven't got a trailer for it yet...
4,067
part of the deal I made with dealer is he did the 1st ( 50 hr) service including pickup( I'm 13 minutes away).
that way IF it's not serviced right, THEY owe me a new BX23S...
that was 260hrs ago......
I did my own 200 hr service....
Zaicran
Oct 8, 2019
72
Morganza, MD
Hmmm, is it 50 hours for first service or 10 hours? Must consult my owners manual immediately...
eDIT: Hmmm, I suppose i'm wrong (as susual, lol)....it's 50 hours.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
Most folks can certainly do the 50h service, just make sure to hit all of the items on the schedule.
Read up on the transmission service, as the terminology gets confusing with which filters get changed. I don't know what a B2650 gets transmission wise.
Even knowing that the transmission service requirement can be confusing, I still got the filters backwards in a recent discussion.
Tornado
793
251
usa
Your first service on the engine oil, filter etc will be at 50 hours. What you may be thinking of is that you should grease the loader zerks every 10 hours of use. This is only greasing however, and yes you can 100% do this yourself with a grease gun. Just clean the zerks up real good and put grease to each nipple until you see it begin to overflow then stop. Clean the nipple again after greasing to wipe it clean of any excess or it will be a magnet for dirt and dust and you dont want dirt finding its way into the nipples.
For the B2650 your 50 hour maintenance will be the first big one. What you will do at 50 hours:
- Change the engine oil
- Replace the engine oil filter
- Replace the Hydraulic Oil Filter
- Replace the Transmission (HST) Oil Filter
- Check all the lug nuts on your wheels for proper tightness.
- Grease the entire tractor, hitting every zerk nipple as described in the manual. There are some under the tractor that you grease at this maintenance. Grease loader again at this time as you should do every ~ 10 hours.
- Check the enginge start system (Stand up frome seat, check pto shut off, etc) just a safety check.
Zaicran
Oct 8, 2019
72
Morganza, MD
Good info there, thank you!!
3,235
just did 200 hr service on the B2650. Easy to do. Stuck a pencil in the HST breather tube. Changed the HST filter and only lost about an ounce of fluid. Just have to be careful with those filters. One turn after gasket contact and they bottom out.
Only other thing was I changed the fuel filter for the first time (never cleaned it) no moisture present. I always use a Mr. funnel when filling the tank. There was no small O-ring in the center of the old filter (and nothing stuck on the housing. Re-assembled with new cartridge and all seem to work fine. I did use a clamp to stop flow from tank.
Zip tied the black air intake tube to the bracket to stop the rattling.
BruceP
G5200H
Aug 7, 2016
837
355
Richmond, Vermont, USA
What? No re-torquing the head-bolts at 50 hours? ... times have changed.
At the very least, I would put a wrench on EVERY bolt I could find to verify tightness. This is not an automobile. A tractor has to work hard and traverse uneven ground.
Sparky73
2018 B2650HSD
Apr 28, 2018
31
WA
Recommend you check out a youtube video or two before diving into the 50hr service. A few different tricks to changing the Hydraulic and HST filters that will save you some trouble along with a significant amount of hydraulic fluid if you do it right.
leveraddict
Apr 1, 2019
906
582
NEPA
Maybe the BX23S is different but without blocking anything and no vacum I removed my HST filter and only lost 2-3 ozs!
nbryan
Jan 3, 2019
1,166
708
Hadashville, Manitoba, Canada
If you just make sure both the HST and suction (hydraulic} filters are ready lubed with a little HYD. fluid on their gaskets, at hand, and you put something under to catch a little fluid that escapes. Spin the old filter off and quickly wipe gasket contact surface then again quickly spin on the new filter. I used no plugging or vacuuming trick and lost maybe 1/3 litre fluid at most to the old towel underneath.
Sent from my Moto G (5) Plus using Tapatalk
