I picked up some rope and it wrapped around the back hoe subframe and the axle. It totally destroyed the right rear axle seal. I have removed the back hoe and its frame and have the axle case exposed. My question is: can I just remove the half case housing for the axle and remove the axle and put in a new seal? I imagine that the axle is held in with a clip. I have a copy of the WSM, but it is of little help. I don't think I have to remove the entire axle assembly to remove the half case. Any help would be appreciated. John in northern VA.
