My saga continues, though it's morphed! NOTE: I'd installed the alternator upgrade kit while simultaneously adding a couple new relay-controlled light circuits; in the process I got the leads to the relays' switch connections reversed (learned all about diodes for use in relays!), resulting in blown fuses, which I wasn't aware of existed (which led me to incorrectly diagnose as key/ign switch problem- new switch out of the deal).
All seems as it was before I'd embarked on all of this, except, the engine won't fire. I'm also thinking I no longer hear the fuel shutoff solenoid clicking. Suspect that I couldn't get it to work if I'm out of the seat: can't reach it to feel it while sitting in the seat! (yeah, need to employ an assistant)
- Plenty of cranking power.
- All fuses (NOW I believe I am aware of ALL of them!) test good.
- Fuel exists up to the injector pump.
- Had been working very reliably up until I did all this work/damage!
- Fuel is fairly fresh, so too the fuel filter (in three years running this tractor I've never had a fuel issue)
I've waded through a ton of postings from here and there talking about troubleshooting fuel shutoff solenoids, but I just cannot find anything definitive for this tractor: many present generalities, which I understand, but I need specifics to ensure I don't go off on another wild goose chase like with the ign switch.
It's a two-wire connector to the solenoid. I'd like to test for proper voltages/continuity. What ign switch positions and wires do I check for what? Do I test between the wires, for continuity? Do I test each for voltage (between, or separately)? In which key setting?
Also, can anyone state with certainty whether there is or isn't a fuel control relay? I've looked at the electrical parts diagrams from Messicks and I don't see anything called such; there is, however, one relay that is just referenced "relay"- totally nondescript.
I'd pulled 12v power from a switched wire off of the OPC wire harness (red with white dashes wire). I'm doing that now and my light circuits are working exactly as they're supposed to. I don't know, however, whether that module/relay(?) was harmed when I'd had the new light relays wired incorrectly: my understanding is that this is all about OPC stuff, and seeing as the tractor will crank over I figure that all the OPC stuff has to be working well enough; also believe that I might not have had the harness plugged in when I'd blown fuses, though I can't say for certain. And, at some point I recall hearing a buzzing noise from one of the relays in the dash: it seemed like it came from the far left side, which is where the nodescript relay lives.
So far I've managed to keep myself busy without the aid of my tractor, but it's looking like I'm starting to run out of such tasks and will be needing a functional tractor pretty soon. Panic is starting to set in.
