B1600 lift arm
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Anyone know where I can buy this part - 67111 3631-3 - secondhand or new. I am looking for the housing but would consider the full assembly
5,117
That part number is an old part number, can't look it up by that number.
The number you need is a XXXXX-XXXXX number.
And no just dropping the last - won't do it.
Can you post a picture of what part you need and maybe I can cross it to the new part number.
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Thanks for your comment. See attached copy of page from parts manual. I do not have any cross ref for new part number.
5,117
Can't read the numbers too tiny, what part do you need exactly?
5,117
Dare I ask...
How the heck did you do that! :eek:
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Tow chain on front which I should have taken off before using the rotovator came loose. You can guess the rest!!!! If I had seen someone else doing it, I would have warned them of the danger. Double standards or what?
Guizerix Tim
B1600DT
Aug 7, 2019
Guizerix, 65230, france
Looks like we both need the same casing part. Mine cracked when overheated and over pressured - case and cap!
The parts look the same as the B8200 and if so are available in UK - They have to come from Japan and Germany and cost about£1000 for both - I’m hoping for a used part!
Guizerix Tim
B1600DT
Aug 7, 2019
You can find the kubota B8200 parts manual online at kubota books
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Thanks. The B8200 casing looks identical. I will add that one to the list of suitable donors.
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Hi Tim
I have located a secondhand part in USA for $250 but freight is more than purchase price (with no good guarantee that part will be a fit) Do you have the page from the B8200 parts manual showing the assembly?
I have reason to believe that several of these parts can be sourced secondhand in US so perhaps we could look at a joint shipment so an EU hub. Delivery to our individual locations by road could be relatively cheaper.
In any case, it will be interesting to compare notes on progress.
5,117
Hi Tim
If you need someone to reship parts let me know, I would be more than happy to do that, as some places hike the price way up on international shipments. ;)
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Thanks Wolfman
I am looking at a getting the unit shipped to Ireland but it slips in between small package and pallet size. Also, the courier companies only offer airfreight. I would prefer to ship by sea with a consolidator. Either way, if another buyer also wanted one in EU, it would make a lot more sense to ship both to one location over here
Incidentally, have you ever worked with https://www.urparts.ie
cornus
B1750, 1600A,B1600
Aug 25, 2015
22
ireland
Hi Tim
I hope you found your spare part. I eventually bought a full B8200 for scrap and took the 3PL off it.
Base fit is same as you said so it should work.
The B8200 has an oil pressure adjustment screw on the hydraulic cylinder cover. I am wondering if I should change the cover for the original B1600 one which does not have the adjustment. No idea why this adjustment is fitted here??
Also, there is some sort of feedback control, via a rod, from the lift are to the hyd system on the B8200. I hope to be able to avoid having to use that as it would take the place of the B1600 control levers that I hope to reuse (they fit the same outlet plate in the main casting).
Finally there is some sort of strike plate attached to the rear of the well of the main tractor housing which I think limits the travel of one of the 3PL lever parts. This has a slightly different part No in the B1600 vs the B8200 lists and I am wondering if that is significant. (only last digit is different).
I would be grateful if someone can comment on any of above
