Diesel fuel return volume
Heritage LogCraft
RTV-X1120, sawmill
Sep 4, 2019
Milladore, WI
I have a used (1600 hours) d1105 engine I’m installing on a sawmill. I’m curious what is a “normal” volume of diesel fuel returning to the tank? After initial startups, I’ll would estimate 1 gallon in 5 to 10 minutes.
Thanks for the input.
hope to float
L3450
Feb 18, 2018
467
60
Ireland
I don't know the amount, but I remember having to run a boat engine straight from the can after the diesel filter got sludged up. From that, I would say that you are not far off in your estimate. I know it was a lot more than we were using to keep the engine running.
5,111
It varies per the engine RPM, at full run I would say your probably about right, and if your wondering, no nothing is wrong with it bypassing so much diesel, it's just the normal operations.
jpf
120
12
butler, ga USA
I have looked into the fuel tank while my 2301 was running and can tell you there is a much larger amount of fuel being recirculated {and filtered} than there is being used by the engine running.
BigG
Sep 14, 2018
1,949
765
West Central,FL
I was always told that the fuel did two things, first to let the engine run with the correct fuel pressure and the second is to cool the pump.
