Female Aux Hydraulic Coupler Seal Kit Installation
Bruce Melde
BX25 M7060HD Z121
Mar 22, 2020
Hutto Texas
Does anyone have any experience they can share in rebuilding one of the female auxiliary hydraulic couplers? Specifically installing a new seal kit. I have one on my M7060 that leaks bad. Would it be better just to replace it?
Thanks Bruce
5,108
Thanks Bruce
Very rarely do I rebuild couplers, the failure rate it too high.
When you rebuild it just keep everything clean and inspect real well.
When you open it up, if there are imperfections of any kind like, pits, scratches, and especially rust, just keep the kit and get a new coupler. ;)
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
306
77
Bagley, MN, United States
The loader connections on my M9540 were leaking a little over time and by just carefully using a non-metallic pick I removed the o-rings from the couplers
- carefully cleaned the rubber o-rings, the o-ring seats, and the outside of the male couplers
- I no longer have any leaking from those connections.
I am guessing that during removal/installation some small bits of dust/debris were introduced and caused the slow weeping of the hydraulic fluid.
