I checked all three (of course they have a common positive rail), and they are measuring 10.95 V after about 4 to 5 seconds (they start a bit lower but get up to almost 11V). The shop manual says we should expect "approx battery voltage" so I suspect 11V is close enough. On the old glow plugs they stamped 11V.Have you verified your glow plugs are seeing the required voltage when initiated?
Your battery should be reading over 11.7 volts if it is at 100% state of charge. Have you had your battery checked? Slower cranking speed can make starting more difficult.I unhooked the positive lead and it now measures exactly the same as the battery voltage (11.7V)
Beex, Yes he did say that he ran it for 30 minutes and it was still hard to start. What he didn't say was how long after running was the start attempt made. It could have been within 2 minutes of shutdown or 120 minutes. Since it wasn't explicitly spelled out, it was worth asking. Agree it should start almost immediately.
I tried almost immediately after shutting it off (after running for 30 minutes). Per whitetiger's suggestion I paid more attention to the solenoid and I think I finally established that is the problem. After cleaning up and spraying some light grease in the solenoid, it is opening and shutting nicely.
Today for the first time it started several times within a couple of seconds! As I was observing the behavior of the solenoid, I found that if I move the key to start start position and then off, the next time I move it to the start (cranking) position, it shuts the solenoid and after about 5 seconds of holding the glow plugs, it starts right up )as in 1 to 2 seconds) IF the solenoid goes back to the ON (open) position immediately when I move the key to Start. However, it can randomly decide to wait 7 to 8 seconds to release the solenoid, which coincides with the 7-8 second delay I have been getting until now.
So it seems that the longer crank times occur when the solenoid it not opening to let the fuel through.
I guess this is either the solenoid itself not going back to the other position, or the key switch not telling it to go back to the open position. Is there any other intelligent system telling the solenoid to open or close?
So while cranking, the solenoid should be on (open) - correct? On mine, when it takes 8 seconds to start, the solenoid stays closed. As soon as it opens, the engine starts. If I had any prior experience, I would have known this But this is one way to get some experience! I love the learning so it is a fun chase. If it wasn't for this trouble, I would not have learned how to adjust the valve lash and test compression. Of course, if I was out on the field mowing all day and this happened, it would be less fun.
I really appreciate everyone's input!
Thanks. I am adding dielectric grease to any connections I pull - is that OK? I am guessing this is a universal good for electrical connections, but I am just guessing. In this case I will need to clean up the dielectric grease on the relay connectors as I squirted some in there without cleaning the terminals. They looked clean, but I will make sure to clean them as much as possible with a small file.Unplug the wire that goes to the shutdown solenoid and see if it starts immediately. If it does, re-connect the wire or use a long screw driver to push the shutoff lever to the no fuel position to shut it down.
The solenoid should only pull in after the key is turned off after being turned on. If it's pulling in when you turn the key on, the module may be bad or have dirty terminals.
I would pull the connector off the timer module in your picture, and check the terminals for corrosion.
My 2230 started not shutting down when I turned the key off, and I discovered there was no current going to the shutdown solenoid. I wiggled the connector on the timer module and it started working. I pulled it off and cleaned the terminals and it has worked fine ever since.
FYI, dielectric means it doesn't conduct electricity. Dielectric grease is designed to be used on electrical connections to prevent corrosion.Yes it’s ok, but keep it on the contracts, you don’t want to create a electrical path between the contacts with the grease
