I'm looking for a belt to connect the TG2739A quick adapter pulley to the tractor pulley. The one given to me when I bought it is too short. Does anyone know the part number or even better the length?
According to D2cat there are two possible belts.
The two belts are B cross section.
The B70001-00509 is a B84 which will mean 84 inches long outside circumference.
The B70001-00515 is a B97 which means 97" long.
If you are buying belts from Kubota, fine, if not then there are a number of good youtube videos on measuring belts to buy outside OEM. However, you have all the info you need except the correct length.
I would suggest the belt you look for outside Kubota has a "P" in its designation such as BP84 or BP97.
The "P" is the generic designation for Kevlar cords which make a much stronger belt.
To get a close length, use a piece of 1/2" rope wrapped where the belt would go and measure its length.
Here is an eBay example of a BP97 belt for $20.
https://www.ebay.com/itm/New-Dayco-...459860&hash=item1c8c686af4:g:jWAAAOSwwxJZde5P
Dave
