bx22 rear axle seal
jtjim
2003, BX 22 RECENTLY PURCHASED, 480 HOURS
Sep 23, 2025
Cortland, Ohio USA
Is there a way to replace the rear axle seal on my 2003 BX22 without dismantling the transmission?
whitetiger
Nov 20, 2011
3,792
2,194
Kansas City, KS
Actually, you drain the hydraulic fluid, jack up the side you are replacing the seal on, remove the wheel/tire assembly, remove the seal, (#50) in the picture above. Remove the snap ring (#40), pull the axle out of the housing.
Remove the other snap ring and bearing from the axle shaft, R & R the seal. Now that "you have taken it from together, you can put it back from apart". Add hydraulic fluid, go play.
jtjim
Sep 23, 2025
Cortland, Ohio USA
Thanks, I have the shop manual. I thought m aybe there was a work-around!
