Completed a full delete on my Kubota 7060. I used Reimer tuning out of Canada. They were super supportive thru the whole process. I have several items about the process which might help someone else if they are considering a delete. The tuners offered by the different companies are the same. It is made in Italy and is very simple to use. The tuners offered comes with a flash drive which has the program you use to download and communicate between tractor and tuner. My Windows 11 laptop would not run the program without some additional Microsoft programs. My Windows 10 computer worked perfectly. I can also offer some work arounds on the DPF removal which will save you time and skinned knuckles. I have some level of mechanical expertise which helped. The nuts and bolts are had to get to, so it is a slow process.
