Reasonably Priced brush guard for L series and MX on Amazon
nwjones18
L4701 HST, RCR1872 Rotary Cutter, RTA1266 Tiller and Grapple
Jan 21, 2021
27
38
Warner Robins, GA
Figured I'd post this since I installed mine today and was impressed with fit/finish. Been wanting a brush guard for my L4701 for a while and had a lot of grapple work coming up, but I didn't want to spend $300. Found this one on Amazon and gave it a shot even though it only had a few reviews. My experience was similar to the reviews on there. Fit well and was an easy install. Only had to drill 2 holes for the top two screws. Worth a look if you've been wanting a brush guard.
Reactions: 10 users
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
You should post a pic of her all protected up.
Something is better than nothing though, Otherwise you'll end up like me.
4,830
Wow....thats a pretty nice find.
Hard to beat a $112 for a grill guard.
Although I am sure it is made with 100% Chinese'ium, that's better than a hole in the grill/radiator. :cry:
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Maxspeedingrods is known to make things from recycled soda cans.
NorthwoodsLife
Oct 15, 2021
1,411
1,472
Wisconsin
It's better than a 'stick in the eye'.
They don't make them for my little LX.
But at that price I couldn't DIY one cheaper.
7,430
NorthwoodsLif, I built my grill guard for $12 in material with two pieces of "drops" from my favorite shop. I had to weld an angle in the center to attach to two pieces together. The punch plate was hard to locate but he had some left over. I thought the holes were too small but they work out real good. No limbs get through, but I put an LED light on top for night work. Attached to factory guard with two "J' bolts I made and put rubber on the hooks so nothing gets scratched and comes off easily if need be.
Get a seat cover while you're protecting your tractor.
NorthwoodsLife
Oct 15, 2021
1,411
1,472
Wisconsin
NorthwoodsLif, I built my grill guard for $12 in material with two pieces of "drops" from my favorite shop. I had to weld an angle in the center to attach to two pieces together. The punch plate was hard to locate but he had some left over. I thought the holes were too small but they work out real good. No limbs get through, but I put an LED light on top for night work. Attached to factor with two "J' bolts I made and put rubber on the hooks so nothing gets scratched and comes off easily if need be.
Looks good!!
NorthwoodsLife
Oct 15, 2021
1,411
1,472
Wisconsin
Well this definitely wasn't made of aluminum.. I didn't measure the thickness, but seemed heavy enough to do the job.
For the sake of if all... maybe put a magnet on it and see if it is ferrous.
WI_Hedgehog
Apr 24, 2024
1,113
1,608
Milwaukee, Wisconsin, U.S.A.
That is a great find even if it's "okay" steel it's really thick for the price. I'd think this is a low introduction price and as positive reviews come in the price will increase quickly.
nwjones18
Jan 21, 2021
27
38
Warner Robins, GA
I think you may be correct. There are very similar looking ones around at the $200 price point. I like that this one has a lower section that also protects from things coming up from underneath. It looks to me like they copied this one from Broken Anvil:
4,830
I couldn't agree more.
That price wont last for long. (y)
drygulch
L3901, LA525, ever changing attachments
May 30, 2024
197
247
Alabama Foothills
www.ebay.com
...Worth a look if you've been wanting a brush guard.
Thanks again for the heads up. I probably would have fab'd something before paying $300ish.
I was overdue as you can see. Now nobody will know...except half the internet...
Greg
