Land Pride Hitch
Rob18530
BX2370
Nov 13, 2023
22
14
Cornwall Ontario
I own a 2014 BX 2370 and I'm looking for a good quality hitch for attachments. I've been impressed with Land Pride Hitches, my question. Can anyone let me know what Land Pride hitch will fit my Kubota. I'm new to the wold of tractors and could sure use some guidance.
Thanking you all in advance.
Chad D.
234
111
Eugene
If you’re talking about a 3-pt quick hitch, I believe the Land Pride QH-05 is the recommended model. The only downside I can think of on this is the non-adjustable top hook. Fine with LP implements and some others, but having an adjustable hook allows the use of a much wider variety of implement brands.
Might be worth seeing if a QH-15 would be an appropriate substitute. I don’t know the answer to that! I just know that I have a QH-10 on my B2650 and wish it was a 15 for the same reason…
mcmxi
4,840
NW Montana
I used to run a QH05 on the BX25D but currently have a QH10 and QH15. I put together this chart for my own benefit but you might find it helpful.
3,849
I wouldn't recommend the QH-05 because it is so limiting. I would suggest the QH-10 as a better choice.
Elliott in GA
Mar 10, 2021
633
613
North Georgia
FWIW, the QH 10 has been discontinued by Land Pride, but they still seem to be available for sale.
I have been very pleased with my QH 10.
BigPapi
BX2380, FEL, 60" LP Landscape Rake and 48" LP Box Blade
Sep 23, 2021
Vermont
I have the Land Pride QH-05 on my BX and it is great, but I can't speak to other than Land Pride implements.
jigsaw
Kubota L2502
Dec 9, 2023
Southwest Michigan
I just got a QH-16. It's the best of both worlds. No need for bushings on the lower pins. Comes ready for cat-1 pins and the top hook is adjustable.
