When i purchased my tractor, it had a broken grille and a missing left body panel. I was able to order a new grille from messicks and found a left side panel on ebay.. i tried to put it on the tractor last week and it seems it doesnt align correctly. The grille went on fine but the panel seems to hit the oil filter and seems to be an inch or so longer as the top bolt holes are off.
When i purchased the panel it was for a b7200 but perhaps the panels are different between hst and a manual trans. The previous owner said a railroad tie hit the front of the tractor causing the damage to the grille and hood. Nothing seems obviously bent and it aligns correctly with the right side. I have a feeling the side panel i got was wrong. Could anyone post a picture or two of their side panel to compare?
As always, thank you!
