M5 cab mouse issues
scott.r.earnest
M5-111, mx5200
Oct 14, 2026
WI
Looking for tips on mouse exclusion, I’ve had the floor taken apart and stuffed steel wool in all of the holes I found. Stuffed all of the control cable and control Rod boots I found. Most everything that I found was on right side of cab. Right rear there’s a rectangular hole that looks like air inlet or air escape for slamming door. I put hardware cloth in there.
Do I need to take the dash apart? Where else are there penetrations?
thanks,
Scott
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,484
678
Richmond, Virginia
I put in rat poison cubes when possible (in spots only the mice can get to, no doggies) , more attractive than soy wires. I also put camphor cubes in mesh bags (lasts about 2 years) in areas that will be dry but potentially cozy for a nest.
Bmyers
May 27, 2019
3,644
4,958
Southern Illinois
I use Grandpa Gus's Mouse Repellent Pouches which you can get from Amazon or a farm supply store. So far, we have had good luck and no mouse issues.
Inside the barn, we put out mouse bait traps (we use Kaput poison, less toxic for any wildlife or the barn cats if they get a mouse that has eaten it).
4,038
2,487
thanks,
Scott
You need to get rid of the critters. Even if you keep them out of the cab, they may nest or eat wiring in the engine compartment.
