Forget the remotes - they work and you have not described anything to suggest they hsve anything to do with the 3pt problem.Thanks for Dan. I have disassembled every part of that block inspected and re assembled but maybe I missed something. All spools o rings and springs were intact and moved easily. This includes checking the shuttle valve on the bottom between the spools and the check and compensator valve. I currently have the aux hydraulic block disassembled.
From my reading my understanding was the manual over ride would operate the 3 pt even if electrical issues, but I could be totally wrong.
it would be helpful to understand the touting of the fluid through the rear end casing. I may remove the 3pt controller and blow some air through the passages to see if they go to the filter first or the block
Like I said - do your best to verify operation of the unloader. If it does not operate oil is just going straight to tank and you will never get pressure at the cylinder.
