another regen question
LenPA
l3901
Jan 2, 2022
37
Sayre,Pennsylvania,USA
I own a L3901 purchased new in 2021. Up until this summer regens occured regularly between 15 and 20 hours. 15 in the winter (snow plowing, firewood) 20 in the summer (finish mower and brushhog). So far this summer I have not had a regen light come on. 44 hours since the last one. I have 403 hours on the tractor. Should I be concerned? It starts and runs fine. I am new to Kubota and deisel tractor. My only other tractor was a 1950 8N I had for 34 years.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,211
1,200
E.
Could you have simply just not noticed the last regen.
When i'm working, my machine's hard, I sometimes don't even notice a regen happening.
If you're not getting any warnings, just run it like you normally do would be my recommendation.
hedgerow
490
479
Malcolm NE
I have gotten close to 70 hours before on my MX6000 between regens and last August we had some 90 MPH winds go threw and took out a bunch of tress so I had a couple friends out helping clean up and put the MX6000 on a flatbed trailer for hauling brush about a half mile to a brush pile. The guy running the MX6000 was idling it a lot and running slow to the pile. About 3/4 threw the day he came pulling into the pile area and jumped off the tractor and run over to the skid loader I was running and said there are lights on the dash flashing on the MX6000. I went over and it was trying to regen but he had it idling. Long story short it was regening about ever six hours the four days he was running it. It took a while after I was running it again to get it back up to were it normally regened. I always run it a two thousand and higher on the RPM'S.
7,378
I have the same tractor also purchased in 2021. Mine goes 40+ hours between regens since new. Your 15-20 hour behavior is not normal and liiely caused by a combination of short run times and operating it at low engine RPM.
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
Ste Geneveive county, MO
I have a L3901DT that I have tracked the regens on since new. I see nothing wrong with the OP's hours between regens. Here is a list of my regens, the first column is the date, the second is the hours on the tractor and the third is hours since last regen:
01-17-15 16.0 16.0
02-28-15 28.8 12.8
03-29-15 40.0 11.2
05-05-15 53.1 13.1
07-14-15 68.6 15.5
10-24-15 81.5 12.9
12-25-15 92.7 11.2
01-30-16 105.1 12.4
02-06-16 118.8 13.7
04-24-16 130.9 12.1
07-10-16 143.7 12.8
07-16-16 156.5 12.8
10-16-16 172.1 15.6
12-16-16 184.5 12.4
02-12-17 196.0 11.5
03-11-17 210.1 14.1
06-24-17 225.4 15.3
10-09-17 238.6 13.2
11-25-17 252.1 13.5
01-13-18 266.1 14.0
02-15-18 279.3 13.2
06-23-18 292.3 13.0
10-20-18 310.3 18.0
12-11-18 323.3 13.0
02-18-19 334.9 11.6
07-27-19 350.7 15.8
11-02-19 364.3 13.6
04-02-20 378.2 13.9
06-15-20 391.7 13.5
11-12-20 406.5 14.8
01-10-21 418.0 11.5
02-18-21 428.6 10.6
10-23-21 441.2 12.6
01-17-21 452.9 11.7
02-26-22 463.1 10.2
06-18-22 476.2 13.1
09-17-22 489.0 12.8
12-26-22 499.8 10.8
02-25-23 511.9 12.1
05-06-23 526.8 14.9
10-20-23 539.8 13.0
12-30-23 551.8 12.0
04-06-24 565.5 13.7
09-07-24 583.7 18.2
12-01-24 598.7 15.0
02-17-25 611.2 12.5
05-24-25 627.1 15.9
08-29-25 640.2 13.1
11-06-25 656.1 15.9
12-23-25 670.5 14.4
01-27-26 682.8 12.3
03-05-26 697.4 14.6
08-10-26 721.4 24.0
09-07-26 732.8 11.4
7,378
01-17-15 16.0 16.0
02-28-15 28.8 12.8
03-29-15 40.0 11.2
05-05-15 53.1 13.1
07-14-15 68.6 15.5
10-24-15 81.5 12.9
12-25-15 92.7 11.2
01-30-16 105.1 12.4
02-06-16 118.8 13.7
04-24-16 130.9 12.1
07-10-16 143.7 12.8
07-16-16 156.5 12.8
10-16-16 172.1 15.6
12-16-16 184.5 12.4
02-12-17 196.0 11.5
03-11-17 210.1 14.1
06-24-17 225.4 15.3
10-09-17 238.6 13.2
11-25-17 252.1 13.5
01-13-18 266.1 14.0
02-15-18 279.3 13.2
06-23-18 292.3 13.0
10-20-18 310.3 18.0
12-11-18 323.3 13.0
02-18-19 334.9 11.6
07-27-19 350.7 15.8
11-02-19 364.3 13.6
04-02-20 378.2 13.9
06-15-20 391.7 13.5
11-12-20 406.5 14.8
01-10-21 418.0 11.5
02-18-21 428.6 10.6
10-23-21 441.2 12.6
01-17-21 452.9 11.7
02-26-22 463.1 10.2
06-18-22 476.2 13.1
09-17-22 489.0 12.8
12-26-22 499.8 10.8
02-25-23 511.9 12.1
05-06-23 526.8 14.9
10-20-23 539.8 13.0
12-30-23 551.8 12.0
04-06-24 565.5 13.7
09-07-24 583.7 18.2
12-01-24 598.7 15.0
02-17-25 611.2 12.5
05-24-25 627.1 15.9
08-29-25 640.2 13.1
11-06-25 656.1 15.9
12-23-25 670.5 14.4
01-27-26 682.8 12.3
03-05-26 697.4 14.6
08-10-26 721.4 24.0
09-07-26 732.8 11.4
I would tell you the same thing I told him.
7,378
Can you point me to something from Kubota that states how long it should be between regens that makes you say that there is something wrong with my engine?
Kubota does not provide that number because its conditions dependent.
Please dont put words in my mouth. I did not say there was anything wrong with your or the OPs engine. Your L3901 regens every 10 to 20 hours. My L3901 easily goes 40 or more between regens. How do you explain that difference?
My explanation is real simple - I operate my tractor at 2200+ RPM and for hours at a time. That reduces the production of exhaust particulates, increases the effectiveness of passive regeneration and increases the time between active regens. Kubota does explain that and advises operators avoid short run times and low engine speeds.
#40Fan
672
498
Does the L3901 have a readout on the cluster showing how full the DPF is? If not, you likely missed it or since you've been using it under a heavy load (brush hogging and mowing), it might not be that full.
I've seen my readout for the DPF lower after I'm starting to mow with my 12 ft. batwing.
Snowman7
May 20, 2020
406
312
Boyne Falls, MI.
My LX3310 is always in that 16 hr range with the exception of one 26 hr interval. I have about 610 hours. I did not run it any different during that 26 hr interval. When I blow snow and mow I am 2350-2400 and when I am putting around I am about 2000.
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
You did say to the OP, "Your 15-20 hour behavior is not normal ....". If it isn't normal that would suggest that there is something wrong.
7,378
Come on man. Read what I wrote.
I was comparing his 10 hour regen schedule to my 40+ number. And I followed up with a comment about RPM and run times affecting regen frequency. Never a mention of engine problems.
In fact I was suggesting his current 40+ hour experience is "normal" and what he should expect.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
290
91
Southern IL
My 3301 usually cycles every 30-35 hours. First few years it was about 25 hours. Even if I fire it up for a quick loader operation, I will let run 15-20 minutes and drive it around just to get the juices flowing.
Fido Farms
L3901, 35 Massey
May 27, 2018
119
Just for info. I have a 2018 L3901 HST. About 560 hrs. My regen similar. 13-25hrs. Its not run hard for hours. Mostly tilling, loader, and snow blowing..
LBZ
'25 GL6060
Sep 17, 2025
53
109
Iowa
GL6060 - 35ish hrs between regens so far with only 80 hrs on machine. Not a lot of idling, mostly running a flail mower at 540 pto speed, some grapple work and road time. And yes I have seen the DPF fill percentage go down while working under load.
