2006 MX5000SU S/N 13470
Fuel cutoff solenoid power goes to zero and tractor dies. Usually happens within 10-90 seconds after starting. Will typically immediately restart and again run for 10-90 seconds until wire looses power so problem is upstream. Trying to find before I start cutting open wiring looms and / or disassembling the dash if -
1-The black/red solenoid wire stays the same color or switches at some point?
2- Does a relay feed the wire or is it direct to the run side of the Ignition switch? If direct feed from the ignition switch which terminal or color wire?
3- If there is a relay exactly where is it located. Is dash disassembly required to access it?
4- Can anyone post a wiring diagram with colors and connectors?
