2008 Kubota BX23 engine in BX25 Temp Gauge Stuck pinned HOT
2,434
@pgrovetom
Since you seem to be electrically oriented and you (or someone) mentioned LEDs, could you use the existing gauge and embed a few leds into it? Maybe three to six LEDs and set them off at different temperatures and color code them?
Basically a digital/analog type of gauge. I think I have seen some on modern car dashes.
pgrovetom
BX25
Nov 21, 2025
27
Sonoma
@pgrovetom
Yes I thought of that and might end up doing that. The reason is mounting a clumsy gauge on a tractor with no logical place that often gets rained on is a problem. I thought of just doing the circuit I already showed and by adding a simple comparator like an LM393 and 3 LEDS for maybe Blue or white =cold, Green = in safe range and Red for too hot. I could just put them inside the existing dash which is waterproof and located in front of the driver. Not a bad method. thanks... It eliminates the mechanical gauge mounting issues which is messy. Its all I need to know anyway. I could even but a small buzzer alongside the red LED as an audible Hot warning. This might just be the best solution. I could just tap the existing temperature sensor voltage entering the dash and calibrate my LEDs for appropriate voltages for cold, normal and hot.
5,849
curious, found these, Amazon probably have them as well...
$5 CDN...... 1/8" NPT. To me it's the simplest solution, leaves original sensor in the block, YOUR 'upgrade' is 100% independent of the original wiring and such.
just checked amazon.ca, 2x the price to $54 !! for same piece !!!
pgrovetom
BX25
Nov 21, 2025
27
Sonoma
Don't actually understand what you are suggesting.
I'm already bread boarding the 3 LED circuit - to put inside the dash where the temp gauge is. I put my dash back together and installed it in the BX25. I measured the existing temp sensor cold and it was 9 volts. I let the BX25 warm up and the voltage quickly dropped and stabilized at 1.75 volts - when the thermostat opened. That suggested to me to light the Blue=cold LED above about 6 volts. Light the Green = normal LED at about 5-1.5 volts and hot = RED LED at less than 1.25 volts. I have a replacement BX25 sensor coming from Amazon. I'll repeat that test to be sure those values are ok with the new sensor. I already changed the thermostat. If not its easy enough to tweak some resistors to adjust the ranges. I'll hide the small bread board PCB under the dash and run the 4 wires for the LEDs up into the dash. Drives for Blue, Green, Red LEDs and fused +12v. This approach leaves the dash alone ( except the tiny LED board) and leaves the sensor alone.
I realized measuring the water temp outside he engine and not Block water temp is risky. If the BX25 lost its coolant, the outside block/head water sensor wouldn't work. But the existing sensor is screwed into the head which will get hot even if the water is gone or not flowing.
5,849
I didn't realize you'd reuse the existing sensor and others were NPT ,so the 'rad hose' adapter looked like a simple solution.
Both temp and fuel circuits will have a voltage regulator on the high side( typically 10 volts ) allows for better more accurate and stable readings. The WSM should have a chart of resistance vs temperature.
I use bowl of water on stove to slowly heat up sensors with a know calibrated themerometer close to the sensor. That way I can plot the sensor's actual response.
Joe.G
BX25 W/601
Oct 13, 2024
82
23
NY
Does anyone have pictures of the Different style gauge clusters used over the years in the BX25 Series? I believe my tractor is and 2014 and looks like the one in the picture I believe or it was used for more than a few years.
2,434
