Post-Clutch Replacement Issues
jland47
L4701DT, FRONT LOADER, IRONCRAFT GRAPPLE, LAND PLANE, BUSH HOG
Jul 17, 2025
LOUISIANA
Just had to replace the clutch on my L4701DT, "guy in his garage" did the job for me, too in depth for me to tackle. Now that I got it back and ran it this past weekend, I noticed a few things that seemed different or I just never noticed before. When I turn the ignition key to on, the fuel pump runs and I could of sworn it would shut off after 10-30seconds, now it will run until I turn the key to off. Can't hear if it goes off when I turn the tractor on. Is this right or did a wire get switched up? The next issue, which is more concerning to me, going between forward and reverse seems really difficult now, it feels real tight and the lever is hard to move. If I take the tractor out of one of the 4 gears it will move easily into forward or reverse, but I though you should be able to leave it in 2nd gear for example and go from forward to reverse?
mdhughes
L3901DT
Dec 10, 2014
1,357
1,121
Ste Geneveive county, MO
I don't think there is anything wrong with the fuel pump.
It sounds like the clutch isn't disengaging all the way and that is why you are having problems moving from forward to revers. You should be able to push the clutch in and move the lever.
jland47
Jul 17, 2025
LOUISIANA
How much free travel does clutch control mechanism/pedal have?
Not much, feels tighter than before the replacement. So if the clutch is not fully disengaging should I be able to adjust the clutch to make it tighter, so it fully disengages?
Fedup
331
127
Winchester
You know it has to have at least SOME free play. If that is minimal already and it still won't fully release with pedal fully down, the problem is deeper than simple adjustment.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,267
174
Coyote Flats,Texas
I agree with Fedup. on clutch mechanism needing some free travel. 1''-1-1/2'' clutch pedal free travel is normal. 3'' free travel of clutch pedal could cause clutch to not completely release. Bent or warped clutch plate could cause non release clutch problems
mdhughes
L3901DT
Dec 10, 2014
1,357
1,121
From the Workshop Manual:
  1. Stop the engine and remove the key.
  2. Slightly depress the clutch pedal and measure the free travel at the top of the pedal stroke. ( Clutch pedal free travel 0.8 to 1.2 in.)
  3. If adjustment is needed, loosen the lock nut and turn the clutch rod or turnbuckle to adjust the rod length within acceptable limits.
  4. Re-tighten the lock nut.
