pin hole rear wheel on BX 2370
vettman
Clifton, VA
Walked out to the barn yesterday morning to find the floor covered with a disgusting brownish liguid. A little troubleshooting revealed the brown liquid was the ballast from the left rear tire on my BX 2370. Close examination of the wheel revealed a pinhole that had allowed ballast to squirt out as the pressure in the tire pushed it out. The ballast was beet juice installed by the Kubota dealer when I purchased the tractor in 2016.
A couple of questions: Is it a common occurence for ballasted wheels to develope pinhole leaks? Should I have the pinhole repaired by brazing/welding, or go ahead and purchase a new wheel? Are the replacement wheels on Ebay or Amazon satisfactory replacements? My closest Kubota dealer is 50 miles away.
Thanks
armylifer
Mar 26, 2013
2,151
926
Thurston County, WA
I would replace the wheel if it were mine. If it developed a pinhole in one place, it likely will develop another pinhole someplace else in the near future. Also, if it were mine, I would replace both rear wheels and try a different ballast solution. I use -20 degree windshield washer fluid in mine. If you do buy new wheels, you may want to consider buying the wheels and tires through your Kubota dealer's sales department, not the parts department. The difference in cost through the parts department is almost double, at least at my Kubota dealer.
vettman
Clifton, VA
My new wheel should be here by the weekend. Ordered from Amazon; nearest Kubota dealer is 60 miles away and does not have a good reputation. My selling dealer in NVA closed up shop several years ago. I will use Tractors Supply 0 deg. windshield washer fluid--14 gals. I will replace the other wheel before I have a beet juice mess to clean up. Thanks for responding to the thread.
cthomas
LX2610 HSDC
Jan 1, 2017
847
562
La Farge Wi
As far as I know beet juice is not corrosive. If it is beet juice like I use it is purple in color(expensive nail) on the garage floor. Now from my Pasquali tractor experience that had calcium chloride in the wheels that was rusty brown in color when I tried to repair the rims(think about 7 tubes of RTV and 2 tubes) that worked for a couple years. Any chance the selling dealer pulled a fast one? Also any chance you will taste it????
3,229
Or you could consider keeping both tires and wheels, removing the liquid fill, and having them filled with foam which is even better ballast than liquid because it fills the tire 100%.
I did this on my BX front and rear tires close to 20 years ago and never regretted it. You need to find a tire dealer experienced with foam filling though. I was lucky and found a place that was about 30 minutes drive one way from me.
Just another option that may or may not work for you…
vettman
Clifton, VA
I got original tire mounted on the new wheel this morning. I could not believe the condition of the inner surface of the wheel. There were multiple pits in the wheel inner surface in addition to the pin hole where the leak occurred. The calcium chloride really did a number on this wheel. I can't believe the dealer did this when he told me the ballast would be beet juice. IMHO, calcium chloride ballast should never be added to a steel wheel withou an inner tube. If this dealer were still in business, we would definitely be having a serious discussion. FYI, we got 12 gals. of windshield washer fluid in the tire, and a new wheel has been ordered for the other side of the tractor.
Here's a couple of pics--the first is an inside view of the pin hole where the lead occurred; second pic is of another pit in the wheel that looks worse the where the leak occurred. There were numerous pits throughout the inner surface of the wheel. Needless to say the wheel is not salvageable
