Sponge Air Filter for Log Splitter
NorthwoodsLife
Oct 15, 2021
1,247
1,232
Wisconsin
So, mice got into my log splitter's air cleaner this past winter and destroyed the foam air filter element. It is a flat 6"x 4" foam air filter element that you oil.
Can I use a standard cleaning sponge saturated with oil as a temporary fix?
My local small engine repair/ parts store doesn't stock a new one and he suggested Amazon.
Amazon can have one too me next week but I planned on using the log splitter today and this weekend.
I am either on to a big savings idea or a flop and a damaged engine.
I am going to cut a cleaning sponge to size and oil it and see if it degrades or melts before putting in in the machine.
Thanks for any advice.
NorthwoodsLife
Oct 15, 2021
1,247
1,232
Wisconsin
Oh, it's a 338cc Champion engine, air cooled, 37 ton log splitter.
A honda engine copy, I think.
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
It will probably be fine for the time being with no filter. It’s not like a splitter is stirring up a bunch of dust.
NorthwoodsLife
Oct 15, 2021
1,247
1,232
Wisconsin
Original filter and cheap cleaning sponge...
Cut cleaning sponge to size in 3 dimensions, and soaked and then strained in 30w.
NorthwoodsLife
Oct 15, 2021
1,247
1,232
Wisconsin
Waiting to see if the sponge has a reaction to the oil....
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,431
1,717
Kalamazoo, MI
Foam rubber has more uniformly sized holes and is more likely resistant to oil. Try a craft store or fabric store.
4,871
NorthwoodsLife
Oct 15, 2021
1,247
1,232
Wisconsin
Well the sponge didn't show any negative issues with oil saturation.
I found mouse poop and urine stains in the airbox and carb, as well as some acorn shells. Ugh!!!
I pulled and cleaned up the airbox and the carb, as mice had crawled into both. It didn't appear that they got past the choke butterfly gate though. I drained the gas tank since I had the fuel line off of the carb. I put an ounce of SeaFoam into the cylinder when I checked the plug, gave it a few pulls w/o plug installed, and let it sit. Also a couple oz SeaFoam into the empty gas tank. Filled the tank. Put it all back together and installed the sponge and it fired up after several pulls.
I let it run for about 30 minutes checking the hydraulics, and the sponge every few minutes. It was working fine.
But, I pulled the sponge make shift air element out after all because I am now concerned with the engine heat melting it. Although I saw that it wasn't melting, I don't trust it.
Thanks for your advice.
