Radiator Genie?
Blue2Orange
Apr 3, 2025
122
52
Bayview Township
On another thread a forum member posted an image of the Radiator Genie set. One for wand for attaching to an air compressor and one for attaching to a garden hose.
BX2380 for those unaware is sort of "backwards". Radiator in the rear. Bit tight space around the radiator for cleaning beyond just the removable debris screen. The wands look to be a good way to clean the radiator. Plus it gives me an excuse to purchase an air compressor. Question is what minimum psi setting is effective to clean dust off the radiator. Also, what psi can potentially cause damage?
Being a frugal (aka cheapo) old guy I was just think about using the shop vac. Suck and then reverse to blow debris off the radiator after vacuuming the debris off the grill cover that sits under the steering area.
Old Machinist
May 27, 2024
371
390
NE FL
I usually just use the leaf blower. You have pretty limited access around the fan.
I do have a homemade water version I use on occasion. It does a better job than the blower and gets in a little more area. I just adapted a water hose fitting to a piece of 3/4" copper tube and bent the end down on a feeler gauge to leave a tight area that increases the water pressure.
Do not ever use a pressure washer! It will bend the cooling fins over. Same would probably go for high air pressure.
Shawn T. W
Dec 9, 2024
154
175
SW Missouri Ozarks
I use somewhere around 100 psi IIRC ... But don't use that much psi on an air filter, Massey Ferguson recommended no more than 30 psi on the paper element, I find that is inadequate, and double it to 60 psi ... I also am amazed the amount of dust I blow out of my alternator ... Try it!
My Massey Ferguson SCUT also is "backwards", as in the radiator is fairly close to the steering wheel end of the hood ...
Sidekick
Jul 29, 2023
982
1,294
N.Y,
I bought a 2 ft long blow gun from harbor freight and put a slight bend in the aluminum tube. Crank the regulator down to 30psi max. Be sure to get everything from the screen tracks so the screen fully seats or the mower deck will blow it up behind the screen fast.
imnukensc
BX2380
Sep 10, 2015
723
645
Midlands of SC
Have had a radiator genie for several years. Rarely use the one for the hose, but use the compressed air one every single time I mow for the radiator, air filter, and blowing dust/debris out from around the mower spindles. I don't worry about psi when I use it. Turn on the compressor which is set for 120 psi and kicks back on about 80 psi to pump back up. Compressor turns off and on as I'm using it.
jyoutz
Jan 14, 2019
3,375
2,412
Edgewood, New Mexico
I just use the radiator genie air wand at about 50 psi to blow out the worst of the dirt. Then periodically I use the water wand to give the radiator fins a good washing.
3,173
1,596
I use an air wand with 6 or 7 holes in it at 130 PSI. Sometimes on really plugged radiators, I run the engine about 1/2 throttle while blowing and add water to the mix with a garden hose. The air sucks the water into its stream and blows it through the radiator.
It has never bent any fins, and it makes a mess on the front of the engine, which rinses right off.
JimDeL
Aug 31, 2022
356
401
Austintown, Ohio
Blue2Orange
Apr 3, 2025
122
52
Bayview Township
No mower. No grass to mow. Just dust from driveway maintenance after new loads are delivered. The 3/4" blue rock without binder used is relatively dust free. But eventually hope to acquire a brush hog to maintain the trails.
Thinking of diy a fitting for the shopvac to get into the tight areas. Vac 1st, then attach the hose to the exhaust port and blow. If it doesn't work well... Have to consider an alternative. And finally purchase a real compressor.
