Summit 3rd function O-ring leak
John T
2017 BX23S
May 5, 2017
1,022
484
under a rock
Recently having a leak at the top fittings ..... where the quick connect fitting screws into the aluminum body.
It uses an o-ring at the base.....
I've tightened it as far as it will go, o-ring seems good.... but still weeps.....
anyone else encounter a similar leak?
I have been guilty of pushing the button in the wrong direction occasionally... putting line pressure into the system... trying to get better about that....
anyway, I don't like the o-ring seal design... seems like a bad design for a pressurized hydraulic system....
I'm gonna take it apart today and see if I can put some thread sealant on it....
5,093
Thats an SAE-08 oring boss port and the gold standard for hydraulic system pressures up to 9,000 PSI.
Tighten the coupler to 40 lb-ft. If it still leaks replace the O-ring. The orings are specials used only for ORB fittings.
Thread sealant on an ORB fitting will do nothing except make a mess and possibly contaminate the hydraulic system.
John T
2017 BX23S
May 5, 2017
1,022
484
under a rock
Thanks Dan
I cut the grass this afternoon so I finally had a chance to take it apart since the loader was off....
I cleaned it up and socked down the bottom fitting to 40 ft-lbs and it seemed to do the trick.
There is also an o-ring on the other end for the pioneer? coupler
. I believe it's a JIC
looks like a smaller or I should say "thinner" o-ring.....
anyway... lookin good for now.
appreciate the tip and info.
5,093
Thanks Dan
View attachment 157440 ..
If the adapters have orings on both ends they are ORB to ORB. JIC fittings do mot have orings.
John T
2017 BX23S
May 5, 2017
1,022
484
under a rock
yeah I thought that was odd....
I looked up the kit....
It says the couplers are NPT
I should have taken a pic while the fitting was apart..... but it stopped leaking so thats all that matters.... for now.
5,093
NPT would have been my first guess but no orings on them either.
