Hooking up third function, rear remotes, and a backhoe line.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
Good afternoon everyone, thought I'd share this image of hose routing for hooking up a third function, rear remotes, and backhoe circuit. Forgive the art quality, i never claimed to be one lol.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
The backhoe goes last because it has no power beyond and you are overpressuring the tank port.
Loader->3rd function->Rear remotes->BH->Block
Your rear remotes probably need a power beyond port for the same reason.
I don't understand how I'd be overpressuring. Could you draw me a diagram of how you'd do it?
5,067
You are feeding the 3rd fumctiom with the tank port on the backhoe. Every time you use the 3rd function the tank port sees that pressure. That can be as high as 2000 PSI and a costly failure.
Before I draw it up what do you have for remotes - OEM or aftermarket.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
Aftermarket, summit. I thought the orange was the supply from the loader circuit.
ayak
L3301 HST
Feb 16, 2018
691
964
WV
OP— have a look at this thread:
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
Thank you
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
Nothing hardheaded in this thread. You asked reasonable questions and listened to my answers. I hope the answers wete reasonable and helped.
They are and they will. Unfortunately, I already had mounted, zip tied, and put abrasion sleeves on the lot of it..... 😮💨. I'll redo it tomorrow
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
I followed your routing, thank you very much for that. I had to relocate the hard bracket for the backhoe because I'm using iso flat connectors and they were interfering with the three point. Now on to creating the bridge between the hoe and kubota subframe.
ayak
L3301 HST
Feb 16, 2018
691
964
WV
Depending on your size, you may end up feeling a little pinched sitting on the mounted backhoe seat while doing work, with the lower part of the ROPS attachment you’re showing.
Here’s how the factory kit instructions said to mount it.
poseidon18
Kubota L2501 DT.
Jun 2, 2025
29
Beaverdam, Virginia
Is that a kubota kit? Mine is from summit. I see your point about maybe being cramped but I'll just have to cross that bridge when I get ther as this backhoe mated to this machine will be a one off.
