B2150 Leaking Diesel
kubotakiller
B2150 HST, B5200 DT
May 23, 2010
22
west kingston, ri
Came home yesterday to the smell of diesel in my garage. I pulled my B2150 out, and noticed a fairly steady drip of diesel dripping down on the right hand side, above the hydraulic block connection / brake pedal vicinity. I haven't had a chance to investigate further on source of leak, but figured I'd reach out here for direction / possibilities. Thanks in advance.
3,163
Your fuel tank may be rusted out if it is steel???
Laughmachine
Kubota B1-15 Bulltra
Apr 20, 2025
Germany
RK - B2150 has a fuel tank behind the seat, this seems to be coming down from right behind the instrument cluster.
This is exactly where the return line from the injectors runs. this was torn on my tractor. it goes from there to the back on top of the tank. Greetings Mario
kubotakiller
B2150 HST, B5200 DT
May 23, 2010
22
west kingston, ri
Thanks Mario for this info/insight and the schematic layout. I will definitely look at this first as I inspect and replace the fuel lines, filter, etc.. I will let you know what I find.
Thanks again
kubotakiller
B2150 HST, B5200 DT
May 23, 2010
22
west kingston, ri
Update:
After removing the side panels and exposing the area whee the fuel was dripping down from, I took Laughmachine's advice and traced out the return line. No apparent fuel leak on it, but I did find the leak on the hose just before the filter where the hose meets the tubing from the tank. New hose cut, installed, bled and seems to be good as new. Thanks to All on OTT.
