Lynch pin instead of snap rings? - BX 3 Point Hitch
QCTEXAS
Kubota BX23S
Apr 14, 2025
9
NE Texas
Got my BX 3 Point Hitch from the dealer and put it together this morning for the first time.
The left and right lift rods are attached using "snap rings". Any reason why I could not replace those with a correctly sized lynch pin?
I can see that the snap ring is going to be a bit more secure, but it is also more of a pain to put on and remove.
Thanks
Martin
7,073
Martin - - had to go out and look at my older BX.
By "Snap Rings", do you mean these things? I'm not sure what they're called either.... ;)
My lift links attach at the bottom with a pin and cotter pin.
Sawdust&Shavings
Apr 25, 2023
135
133
Stafford, VA
Thanks
Martin
I use lynch pins…agree with you that they are easier to install and remove.
7,073
I don’t see an issue, but would caution that all lynch pins are not created equally.
If the clasp fails, could be a mess.
These are both same size. Black one is more stout and has much more clamping force. Difference is $1-2.
2,417
Those black ones are AWESOME but keep your fingers out of the way when closing them - or you might say a bad word or two!
Reactions: 6 users
jyoutz
Jan 14, 2019
3,441
2,529
Edgewood, New Mexico
I’ve experienced what you speak of.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
455
441
Amsterdam, NY
I'm confused. I've only had my tractor for three years now and have never taken off the lift arms or any part of the 3 pt. off. Except for maintenance why would I want to? Just asking to expand my limited knowledge.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
209
334
Grayling, MI.
Oh, I know what they're called, but I just came on this forum and don't want to get kicked off. 😂 I would call them a spring ring.
Sawdust&Shavings
Apr 25, 2023
135
133
Stafford, VA
I have the pto powered GCK60-23BX Grass Catcher for my BX1870-1, this version does not use the 3-point hitch, some variations do. In order install it the 3-point hutch must be removed.
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
46
24
Va
On my B2650 when I put the backhoe on I’ve got to take the 3PH off
QCTEXAS
Kubota BX23S
Apr 14, 2025
9
NE Texas
On my BX23S I have to take off the 3-point to use the backhoe.
And originally I called them "Snap Rings" because that is what it called them in the instructions.
JonM
Nov 29, 2024
115
237
wisconsin
you can use a lynch pin to secure a clevis pin. if your using lynch pins just be sure it will fully close and stay closed in all orientations. you shoildnt use these as a load bearing pin
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
143
101
usa
While doing some heavy brushing hogging, blackberry vines etc., I have had the lynch pins pull out. They were not the heavy black ones.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
101
107
Bloomington, IN
While our property is pretty flat, the ride can be bumpy. In my years of Bota ownership, I've managed to shake loose/lose some crucial pins at the most inconvenient times and as far as possible from the barn. A lot of the pins are for adjusting/easy removal of stuff that I'll never change. Others I may pull once a year or less (like removing 3PH quicktach to mount heavy rear grader blade).
I've been lucky so far and not damaged my machine when a pin falls out, but I've made a point of replacing as many as I can with grade 8 bolts and nylock nuts. The minor inconvenience of using a wrench and ratchet to pull my grade 8 "pins" pales in comparison to the potential damage and injury that could be caused by a missing crucial pin.
animals45
L3301l
Apr 22, 2021
282
Mabie CA
the instructions for my BH77 for my 3301 says to remove 3 pt . We just remove the 2 rams on the TnT & fold the lift arms up & wire them in place & install the Hoe .
QcTexas ya may take a closer look at yer setup . I used to drag my feet real bad when it came to Hoe install time , not so much now .
animal
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
373
161
Southern Worcester County, MA
Never seen the black ones before, where'd you get those?
FTG-05
Jul 21, 2013
325
169
TN
Any farm type supply store should have them. Tractor Supply has them as well, but I despise TSC. I get mine from the Hwy 53 Farm and Hardware store.
