Adding Draft Control to MX5400 with Rear Remotes
doornail385
9
Hello everyone,
I recently helped someone with box blade work using a tractor with draft control, and now I'm eager to add it to my MX5400 ROPS. My tractor has three rear remotes, with the second remote featuring a float detent.
From what I've read, Kubota suggests that a spool with a detent cannot be used with draft control and I would have to replace it with a spool without a detent. However, after inspecting the remotes, it seems the only difference is a slightly larger assembly at the bottom for the detent spool. The parts diagrams suggest it shouldn't interfere, but I'm not entirely sure.
Could anyone with an MX5400 or MX6000 that has draft control share pictures of the linkage and the area where it connects to the hydraulic cylinder case? Any insights or advice on installing draft control with a float spool would be greatly appreciated.
Thanks in advance!
9,207
Hello everyone,
Thanks in advance!
I realize that this thread is almost a year old, and not sure how I missed it, but I have draft control on my MX6000 and have three rear remotes with one being the FD (float) variety. I can take some photos today of "the linkage and the area where it connects to the hydraulic cylinder case" if they're still needed.
I was running the box blade behind the MX last week (now switched out to the grading scraper) and had draft control on the most sensitive setting and it worked well.
armylifer
Mar 26, 2013
2,158
942
Thurston County, WA
OP was a new member with only 2 posts and last seen in November of 2024. My bet is he is not coming back for an answer to his post.
CWiley
MX5400dt
Apr 17, 2023
Missouri
While I'm not the OP, I am thinking of putting in a couple food plots that I may plow/disc, and am curious if adding draft control is worth the investment on my MX5400. I have 2 rear remotes, one with float. I also use a rotary cutter, tiller, box blade, and grader blade fairly often. So the draft works with a box blade, too? How about on the others? Thanks
9,207
In theory, draft control works with any implement that puts a variable rearward force (pull) on the 3-point. The position control lever controls the depth of the implement, and the draft control lever controls the sensitivity to changes in draft (changes in pull on the 3-point by the implement). @MtnViewRanch has a lot more experience with draft control and can more than likely answer all of your questions.
For the record, I have draft control on both tractors and ordered that feature when I ordered the MX. It was $1,050 installed back in the fall of 2021. It comes standard with the M6060/M7060 models.
MtnViewRanch
871
309
Lakeside Ca.
Draft control can be beneficial with both your box blade and your rear blade. Pretty much anything that has a cutting edge that puts a drag on the tractor and is connected to the 3pt hitch.
Learn when and how to use it and life will be better.
I believe that an exception to the cutting edge statement would be it also works with a 3pt disk. ;)
CWiley
MX5400dt
Apr 17, 2023
Missouri
McMXi - This makes more sense and explains a lot.
OK. Thank you both for the feedback.
doornail385
9
Thanks for the input. I already ordered the kit and installed it this weekend! If didn't route anywhere near the spools and fit perfectly. I guess Kubota is concerned that you could had a top and tilt with one of the cylinders in float while trying to use the draft? Both my local dealer and Messics said it's not compatible if you have the FD spool via some note in the Kubota info.
doornail385
9
That totally almost happened. I got an email when CWiley replied, but not about any of the other posts. I came to let CWiley know it fits and found a wealth of knowledge I missed.
armylifer
Mar 26, 2013
2,158
942
Thurston County, WA
You will have to adjust your email and content preferences so you can get emails whenever someone posts to your thread.
Email options
  • Receive news and update emails
  • Receive email when a new conversation message is received
Content options
  • Automatically watch content you create…
      • and receive email notifications
  • Automatically watch content you interact with…
  • Show people's signatures with their messages
5,632
Having a cylinder in float should not affect draft control. My guess is the problem is physical interference which is a common issue with Kubota remotes.
lostarnes
MX5400
Jul 21, 2025
NC
Do you have any pictures or would you mind taking some from the rear and also the installed linkage? I just received the kit but would like to see how it’s supposed to look installed.
Brewboy
Grand L4760 with loader, grapple, cutter, box bladecanada
Aug 16, 2025
11
East Texas
I have a L4760HST and would really like to see your images. This is a new tractor and the dealer installed draft control has never worked, in fact it prevents me from lowering the lift arms. The dealer is supposed to come pick it up on Monday and put a new draft system on it. I would like to be somewhat educated as to how it works. FYI I also have a Ford 4610 with a factory installed draft and we use it all the time for box blade on a road with many slope changes.
9,207
There's a process listed in the WSM to adjust the draft control rod but it requires a draft control test bar. The WSM states "the special tool is not available, so make it". Seems kind of curt don't you think? 😂 I'll take some photos this afternoon.
Brewboy
Aug 16, 2025
11
East Texas
I saw the DIY tool, but I couldn't find an adjustment procedure. Yes, I think it's pretty silly to sell a dealer addon option and not sell the tool to adjust it.
If you don't mind, could you please point me in the direction of that procedure. I realize we have different tractors, but just knowing what section it is in yours should help me find it. I am going to look again. Thanks.
Edit: Within the WSM I did a search for the word draft and got 5 hits. Four of them take me to the test arm dimensional drawing. The other one had to do with the grease fittings if equipped with draft.
9,207
I have Kubota installed draft control on both tractors with no issues. If I need to check and adjust at some point I'll make the tool.
9,207
@Brewboy, I took some photos this evening of the draft control on the MX but not very good ones upon further review. I'll pull the tractor out tomorrow and try to get better ones. Messick's has some good schematics of the various components in the draft control kits if you need to see parts.
