Who did I piss off??????
5,704
Man one thing after another, life is good,, HACK,,, grrrrrr ,,,, late charges for stuff I already paid, I know cause I checked the back and checks cleared, ran over the damn sundial chewed it up and I have no idea where the arrow went,, nothing flat,, yet,, Winds knocked some Beatle killed pines down, so nice day chain saw time,,, nawww this little POS Stihl MS211 has never been right from day one, shop says nothing wrong,, no start,, ok check plug, no spark, check gap on module, of course you have to take all the plastic off first, it is laying almost on the fly wheel OK one business card later set between 15 to 20 thousands should be good,, check plug gap .020 good,, put it back together and pull and pull and do I get a spark,,, nawww ,,, then maybe a spark. maybe not. OK let try it hope upon hope,,, nope not even with juice ,,, nada. I never had problems with the Husky or even the old 10 10 Mac pro. OK Im done venting, I just hate to order a spark module and not be the problem, yeah I know its like 60 bucks on line but still.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
688
755
Indiana
I was having problems getting consistent spark on an old Honda rototiller during daylight hours. When the area was dark, I could see better consistent spark. I probably have a gummed up carb.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
239
260
Pennsylvania
Around here.... nobody wants a 211....they go with Echo, I agree with that.
5,704
The 211 was a quick need buy, good for small limbs and light stuff. But I need one that is going to pop off when I need it. Hate spending 600 + bucks on another saw
5,188
Stihl, battery powered saw!
dlsmith
BX2230, LA211
Nov 15, 2018
1,367
1,064
Goshen, IN
I had a Troy-Bilt 4 stroke weed eater for 10 years or so, always ran the fuel dry in the fall and checked the plug so it was ready for spring. It always started after a few pulls and ran great. A couple of years ago in the spring, I gassed it up to do some trimming and it refused to start. Rebuilt the carb, replaced the plug, replaced the ignition module, checked the valve lash and checked the compression. No matter what, it wouldn't start. It had spark, but wouldn't fire, even on ether. When pulling the rope start, it acted like the timing was advanced. Pulled it apart to check the flywheel/crankshaft key, it was fine, and it looked to be in time. After about 10 hours of futzing with it and a lot of cursing, I gave up and bought a new power head.
Sometimes I hate those little engines.
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
711
1,066
Hayward Wi
Boy, sorry to hear that. I've got the same Stihl 211 and it's been my go to saw for several years. The only difference, mine was given to me strait gassed and I had to rebuild it. Could you have a short in the kill switch wire or plug wire??
Yooper
3901 LA525
May 31, 2015
1,752
930
NE Wisconsin
Chainsaws are the most temperamental things this side of …umm…well…I better not go there!
Sounds like you’re looking in the right place for the fix. Good luck skeets!
9,118
My Husqvarna saws have started each time, every time, by the 4th pull of the rope.
My boss is a huge stihl fan. But all I've seen is when he brings it into the shop because it won't start again. 🤷‍♂️🤷‍♂️🤷‍♂️
Yooper
3901 LA525
May 31, 2015
1,752
930
NE Wisconsin
Pretty much the same here for my 455. It’s when you use it for a while and let it cool down a bit and try and restart it is when it gets temperamental. I’ve learned to let it idle for a minute before working the throttle is the trick. If you use the choke it will flood.
5,704
Yes Sir, the muffler somehow fell off my Husky ,,, coffcoff,,, second pull and with a good sharp chain,, it was hard to keep up with, she screamed, untill she didnt !! Yeap I m thinking a coil pack I think it was 55 or 60 bucks for OEM, on felabuy, but sometimes even then you have to hope for the best, ya never know if it is one of those counterfeit parts
Gaspasser
L6060, FEL, forks, BB, rake, snowblower, KX033 mini-ex, dump truck, splitters.
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Ditto.
Tru dat!
Hmmmm. I run into trouble restarting my husqvarna saws after they run a bit and are warm. Let it sit for an hour or two and starts up again.
I alternate between 3 saws so I can keep going as the others cool down..
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
84
Waterford, Maine
I don't want to upset anyone but to my understanding Husqvarna ceased production of their petro products including chain saws. I believe they closed the factories, and now are only going to go with battery powered tools. You might check before you buy.
5,704
(&()*^^^&*#) ...grrrrrrr, I hate putters !
5,704
I was at TS yesterday and they had a ton of Husky chain saws, I know they got out of, or were getting out the mower and yard tractor business. I think after they restructured like the tillers and low sellers were gone too. The chain saws dont seem to be on the chopping block
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
The performance of my Stihl MS250 has been flawless. It has never had stabilizer added to the fuel. It has sat for well over a year without being used since buying it new possibly 20 years ago. This year it took 4 trees down in a period of a few months. It starts without issue. A pull or two with the choke full on, and another pull or two gets it running. It isn't a large saw, but it can do a lot of work for its size.
The other two saws here are a 20V DeWalt 12" chain saw and a 20V DeWalt 8" pole saw with an extension. These are handy for quick small jobs. The pole saw is great for snipping the branches off a dropped tree without having the wade into them. It also is handy for trimming trees for tractor clearance if the branches are too big for the 20V pole hedge trimmer.
4,043
2,494
Are you maybe thinking about Makita? Mine is now orphaned.
