slot cutting jig
drygulch
L3901, LA525, ever changing attachments
May 30, 2024
201
256
Alabama Foothills
www.ebay.com
I had been needing an efficient way to cut clean-ish 1/4" slots in some 5/8" stock. Went through a couple less than ideal solutions. Finally fabbed up this nice one for my needs, which seems so obvious after the fact...but don't they always...
I had originally cut out a piece of 1/4" plate and then went looking for an arm to weld it to when I stumbled on my stock of angle iron. Oh...duh!
5,521
Now that is thinking out of the box! (y)
I like it!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
I like that! If you want to cut multiple slots (like teeth on a comb) you could tap the top leg of the angle iron and have a bolt sticking up next to the disc to automatically space the slots.
drygulch
May 30, 2024
201
256
Alabama Foothills
www.ebay.com
Could make dovetail joints in steel that way! šŸ˜†
Actually, I may want to control thickness from one side and may employ that. Maybe removing exposed threads.
Thanks,
Greg
drygulch
May 30, 2024
201
256
Alabama Foothills
www.ebay.com
NICE!!!! I should make one, just to 'require' me to go to my favorite steel dumpster.
Thank you!
FWIW, this one might be more generally useful. I love this thing and use it regularly.
Was just a quick and dirty fab for some long forgotten project. But I've used it tons over the years and wish I'd spent more time squaring it up properly, sizing the slot, etc.
Greg
Sidekick
Jul 29, 2023
1,276
1,833
N.Y,
I'd put a safety shield over it. Those thick grinding wheels don't have the same reinforcing as the thin cutting disc's and can break when cutting from the side. I had one break trying to cut a slot like that.
