Billy Goat leaf blower Question
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
193
76
Waterford, Maine
The other day I bought a used 14 hp Billy Goat blower, and it is in fine shape. Of course I won't be using it for awhile, as it is full time winter in Maine now. But I wanted to service it for when I will use it. I have a unique problem. I can see where the engine gear oil get filled and drained, but the engine oil, I can see the fill, but not the drain. The oem, and videos etc online show nothing. if someone has one of these, just give me a clue. tnx
John T
2017 BX23S
May 5, 2017
1,041
513
under a rock
Is it The SUBARU engine?
My Billygoat has the EX 13 lump
the drain plug is under the filler tube. to the left.
5,723
hmm, from their website...
Vanguard, Honda, B&S engines....no Subaru mentiond
also weird , no HP in the 'specs' list !
and MY vanguard engine IS a B&S.....curious.
MOOTS
MX6000
Jun 27, 2019
2,177
2,696
Canton, Georgia
Post some pictures. If this is a walk behind unit, the blower is direct drive from engine, no gearbox. Atleast the 3 we have at work are.
Should be a simple drain and fill of the engine.
Downeaster
Oct 18, 2022
193
76
Waterford, Maine
I am sorry I didn't elaborate on which engine it is. It is the Vanguard engine. I know there has to be a drain plug there somewhere.
Downeaster
Oct 18, 2022
193
76
Waterford, Maine
Yes, I know, but I have looked even with a small flashlight but can't see one. I'm expecting to see one of those small 1/2 or 3/8 screw out bolt like the gear drain plug has. Vanguard engine 14HP
Mine is the 14hp Vanguard engine.
5,723
I'll have to look at my 16HP VG but seem to recall bottom of the fill tube, there's a drain port.
Old skool ,it was a pipe plug, new ones a plastic 'sleeve' you turn to drain the oil out....
3,099
My 16HP Vangaurd has the drain at the back center of the engine base.
3,099
It also has a second one in the same place except in the front.
MOOTS
MX6000
Jun 27, 2019
2,177
2,696
Canton, Georgia
Something like this? That is on a 40horse vanguard on a scag zero turn.
If that is what you have, that is the engine drain.
John T
2017 BX23S
May 5, 2017
1,041
513
under a rock
Well, If you can't find it or rare chance there isn't one (I doubt it)
You can always use a mighty vac.
I've used the mighty vac on a couple engines over the years that always seem to develop a niggling leak at the drain plug...
stick the tube down the filler hole, a couple pumps and it gets sucked right out.
Actually that concept is being used in a lot of big truck garages. All our new trucks get it installed.
It's a separate hose right to the sump.
(oil evacuation system)
It purges the oil filters /evacuates the sump and prelubes the engine for no dry start.
no spills either.
cuts oil/filter change time more than half.
6,932
Anymore - - seems like most of my drain plugs look like those the guys pictured, irrespective of the engine manufacturer.
I'd start looking for one that looks like that down at the bottom of the case.
Downeaster
Oct 18, 2022
193
76
Waterford, Maine
I found it directly under where you pour in the engine oil, Hard to see up underdneith. i can agree that taking some pic would help only I don't have smart phone or camera.
Downeaster
Oct 18, 2022
193
76
Waterford, Maine
My mistake. It appears that every drain I see it for draining engine oil, and there is no gear box. I'm just going to replace engine oil with new, and not worry about it.
John T
2017 BX23S
May 5, 2017
1,041
513
under a rock
Yeah I was wondering about that....
Those blowers are basically an engine and an impeller inside a housing.
Downeaster
Oct 18, 2022
193
76
Waterford, Maine
Turns out I was making too much of this. The gearbox is only on the self propelled models, and if I had thought that out better I would have realized that. Unfortunately it is a product like I have never had, and being someone that wants my items to be fully protected with the best maintenance. I foolishly tried to follow Billy Goat specifics, so purchase necessary fluids, and then find out buying the gear case lube, was totally unnecessary. Hate to think how numb I will be at 85. Thanks guys, for helping this old man.
