Where to tee for sump return.
tnmike
mx5800
Nov 13, 2018
Jacksonvillle, Fl US
Hi all,
I've been looking at the Lane Shark for a few weeks and comparing it to an offset flail mower. For my property the front end LS will just be better. I'm trying to learn about hydraulics and have made some progress but.....I need help.
I called the company and since I have a 3rd function for a grapple all I need is a tee and a hydraulic line back to sump. And yes, a switch if I don't want to hold the grapple button.
So, I see color coding "dots" marking lines and some lines without coding but I wanted to confirm where it's better to put a tee to the sump. There are elbows at the loader attachment area and also elbows at the "block" just under the step-up by the HST.
Here are pictures of the two areas. My guess is the lower elbow at the block that isn't color coded. Is this correct?
Any help is very appreciated.
7,327
Hi all,
The lower elbow is direct to tank. You can tee into that connection either there or at the loader valve.
Just be aware that when the LS is running you will not have the use of the 3pt or your rear remotes if you have them.
tnmike
mx5800
Nov 13, 2018
Thank you Dan, appreciate it.
I will probably use that lower elbow at the block. The loader area seems a bit congested.
7,327
I am gueasing you will want a quick coupler on that connection. Thats probably most conveniently mounted up by the third function couplers.
tnmike
mx5800
Nov 13, 2018
Dan, good idea if I have it right. So a new permanent line that will mount from where the grapple connects - a quick connect there and run to the tee that I put in at the elbow on the lower block. That sound right?
Here is a picture of the 3rd function lines for the grapple.
Mike
7,327
Mike
I assume those hoses have quick couplers on both ends. I was thinking a third hose run alongside those. That allows you to easily remove the loader.
on the tractor side you would run another hose from the return tee on the outlet block up to the two existimg ones at the top of the boom. Loader now comes off with 7 rather than 6 quick connects
tnmike
mx5800
Nov 13, 2018
Thanks Dan for all the good help.
You're right with just a single hose with quick connects at both ends. Heck, I'll just zip tie it to the other hoses and form a mount on the boom. I think the only thing to be careful about is plumbing the tee so it doesn't stick out to far from the frame step. I'll see what I can find.
AllenBC
L3901, L525 Loader, BH77 Backhoe, Lane Shark LS3, Pallet Forks, Snow Plow,
Jul 10, 2024
66
27
Warwick, New York
My "reply" isn't a direct reply but a related question.
I have a Lane Shark and used it last summer with a WR Long 3rd function with the C-Flow kit that provides a return bypassing the 3rd function spool valve. [It also has a loader handle with buttons for regular 3rd function operation and a third button that pressing 3 times keeps fluid going to the Lane Shark without holding a button down.] The kit provides a separate quick connect at the front for a return circuit that "tees" into the power beyond circuit just after the 3rd function spool valve. I understand this avoids hydraulic fluid heat build up caused by returning through the 3rd function spool valve.
But wouldn't it be better to have the return go as directly to tank as possible? Bypassing the BH77 backhoe on my L3901 by removing the quick connects from the backhoe and plugging them directly into each other should help.
But a direct line from the dedicated C-Flow quick connect teed to the return line from the bucket dump circuit might be better since I think that goes directly back to tank. Doing it this way would provide a shorter hose run and would not interfere with backhoe function. In this case the 3rd function valve would work as originally designed since return from a grapple or a snow plow would be through the 3rd function valve as intended. I also shouldn't interfere with loader function.
BUT I am a rank amateur fully capable of thinking myself into a hole. So here's hoping Dan will steer me clear of holes like he did with my other hydraulic snafu's.
